Old 10-23-2015, 07:43 AM   #1
jb92563's Avatar
Catalytic Converter dead
I got the engine light for the dreaded dying catalytic converter P0430.
I have a CA smog inspection due by Nov.
I tried the "Guaranteed to Pass" fuel additive. No Luck.
I tried replacing the down steam sensor even though I could see on the Durametric that it was following the upstream voltage sine wave instead of a strait line as it should be, indicating the CAT is dead. No Luck.
I only have that P0430 code so its not likely anything else.
I discovered that there are electronic devices that emulate a proper functioning downsteam sensor for a good CAT, but if a tailpipe sniffer test is used and they stick the probe in the passenger side exhaust they will likely detect excessive emissions.
However I could reinstall the downstream CATs and it would likely pass with the Electronic cheat (~$70).
But in the end its an inconvenience to reinstall the rear CATs every 2 years.
So it would be better to buy a replacement passenger side Header CAT.
I suppose I could buy a used one, which I prefer at this point to save some bucks, or I could bite the bullet and buy a new ~$1800 CAT.
Are there any other options I have overlooked?
Does anyone know of a used one for sale?
What is the best price/site for buying a new CAT?
