Old 08-20-2015, 09:12 AM   #1
Clutch replacement tool checklist
I'm diving into changing the clutch this weekend so what are the special tools I will need other than the triplesquare for removing that one pesky tranny to engine bolt, a flywheel lock tool and IMSB replacement tools?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 08-20-2015, 10:20 AM   #2
still plays with cars...
BoxsterSteve's Avatar
The most important...
You seem to have the basics covered.
Vital for stress breaks:
Brand not as important as quantity.
Six speed 2000 Boxster S
Old 08-20-2015, 10:48 AM   #3
  1. Go to Lowes and get two overly long bolts of the same size as two of the outside bell housing bolts, but about twice as long. Cut the heads off to make "guides" to assist during reinstallation.
  2. Look up a company called Kingsborne Wire Works; for $10 they will sell you the same clutch disc alignment tool Porsche sells for about $50.
  3. Either locate the proper RMS installation tool (sells for about $600, so try to borrow or rent one), or make your own out of some PVC pipe and other bits.
Old 08-20-2015, 10:58 AM   #4
So the plastic alignment tool that comes with the clutch pack is no good?
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 08-20-2015, 11:27 AM   #5
steved0x's Avatar
If you take the bolt to the section that cuts and sells chain the can use the chain link cutting tool to cut the heads off the bolts for you.
Old 08-20-2015, 12:15 PM   #6
Guys
Which one of these is the triplesquare I need.
Sears.com
Sears.com
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 08-20-2015, 12:26 PM   #7
If you get one with the clutch it will be fine, but not all come with them.
Old 08-20-2015, 12:58 PM   #8
Guys
Sears.com
Sears.com
Unlikely either of those will work in their current form. The triple square bolt is tricky to get to, and getting a ratchet and socket to it is nearly impossible. I use a cut off hex bodied triple square bit with a wrench to get that bolt out. Then I throw it away and leave that hole empty, for ease of change at the track.
Buy the first link and be prepared to cut it down.
specboxCO is offline   Reply With Quote
Old 08-20-2015, 01:54 PM   #9
And,
Any opinions on this clutch kit.
Porsche Boxster Clutch Kit 5 Pc Set - Original EPS: Transmission and Clutch &amp Clutch Kits
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 08-20-2015, 02:54 PM   #10
epapp's Avatar
Jesus, that is cheap. When I did mine, recommended solely because it is hard and expensive to change again, was a Sachs clutch. Its ~$700 but you know without a doubt you won't be servicing it again in 2000 miles because the clutch disc ripped apart or broke.
Old 08-21-2015, 07:14 AM   #11
1999 base
Meir's Avatar
Hi San.
i have all the tools you will need for the job.
you are more then welcome to come and pick it up.
Old 08-21-2015, 08:17 PM   #12
amagalla's Avatar
I'd stick with the SACHS kit that came on the car. RockAuto has them pretty cheap and it comes with the tool, and the bearings.
Tony
Lapis Blue 03 Boxster S
Old 08-22-2015, 07:23 AM   #13
Hi San.
Meir
Thanks so much for the offer. I was just about to post if someone could lend me/rent me the tools and you beat me to it. A true gentleman.
The plan is to get the trans out this weekend and assess the situation, so I may take you up on the offer next week.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 08-22-2015, 08:06 AM   #14
Sachs Performance Clutch Kit
Tony
San, I bought a Sachs Performance Clutch Kit (disc and pressure plate) directly from Sachs and now with the Euro vs USD almost equal it came almost half price that the same ones offered on the USA even with the $45 shipping charges.
PLMK if you want the link for Sachs
Old 08-22-2015, 06:38 PM   #15
1999 base
Meir's Avatar
Meir
No problem.
I will send you a PM with my phone number.
If you want, you can even come by tomorrow. I have the 10m triple square cut to size and a special 10 mm long wrench that makes that annoying screw easy to get out.
I can also lend you a transmission jack, RMS and IMS tools if you plan on doing that.
I have done this project three times so I can give you some pointers if you like.
Give me a call any time.
Old 09-02-2015, 10:57 AM   #16
A couple of questions.
Whats the final word on the depth of the RMS. I'll be installing it with the very expensive Porsche factory tool (thank you Meir) so I believe that will install the seal to the right depth.
Whats the final word on the degree torque of the flywheel bolts. 90 degrees or 120?
Thanks all.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 09-02-2015, 11:49 AM   #17
Thanks all.
If you are using the correct factory tool (9699 and the 9699/2 insert guide), you do not have to worry about the correct depth, the tool will set it to 13MM (measured from the crankshaft flywheel mating face) automatically.
Flywheel bolts are torqued to 19 ft. lb. plus 120 degrees.
Old 09-02-2015, 11:53 AM   #18
That was quick! Thanks.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 09-06-2015, 08:13 AM   #19
There may be little twist to your question. It depends if the c/s is marked by the old seal. If the engine is a total rebuild,it is not an issue .
You don't want the new seal to be positioned exactly where the old one was(and was leaking).The new seal needs an unworn,smooth c/s surface to seal on.
Then there is the sealant/no sealant issue.The latest PU seal is no+sealant.
JFP is the expert on this whole subject.
Research diy,PVC coupling for inserting the seal if your fabrication skills are very good ?
Per JFP.Get the correct 5/6 speed tool!
http://www.clutchtools.com/index.php?productID=40066
http://www.clutchtools.com/index.php?productID=40065
Old 09-16-2015, 02:40 PM   #20
DennisAN's Avatar
If I'm not too late...
The $300 LUK clutch kit for the 2.7l is the SAME as a Sachs kit....LUK just boxes up Sachs parts.
I got mine from RockAuto for $300 shipped with their discount code. The Sachs parts bear the same part numbers as the OEM ones removed from my 2000 base 986. It also has the OEM bearing mfgs. plus the alignment tool and pack of grease.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
