Old 09-02-2015, 11:49 AM   #17
JFP in PA
A couple of questions.
Whats the final word on the depth of the RMS. I'll be installing it with the very expensive Porsche factory tool (thank you Meir) so I believe that will install the seal to the right depth.
Whats the final word on the degree torque of the flywheel bolts. 90 degrees or 120?
Thanks all.
If you are using the correct factory tool (9699 and the 9699/2 insert guide), you do not have to worry about the correct depth, the tool will set it to 13MM (measured from the crankshaft flywheel mating face) automatically.
Flywheel bolts are torqued to 19 ft. lb. plus 120 degrees.
