Old 07-04-2015, 05:08 AM   #2
flaps10's Avatar
The first four are oxy sensor codes. Both sides, after the cats. One code each side is telling you the number is low and the other is telling you the signal is being interrupted.
Obviously, check for connections first. Any chance you're trying to install non stock headers?
The last two are SAI (secondary air injection)
I take it the car runs now?
flaps10 is offline   Reply With Quote
