Old 01-02-2017, 07:49 AM   #61
The guy who spun out should have hit the brakes instead of letting it roll backwards across the track. The Miata didn't have anywhere to go.
1941 Dodge Luxury Liner Coupe
Old 01-02-2017, 10:17 AM   #62
The Radium King's Avatar
things happen on the track. ultimately it was up to the miata not to hit the vette. there was room to stop. he made a call, it didn't work out, no one was hurt. i understand his call - i decided not to stop too - the corner into that mess is fast, and peaked like a road so that the outside is off-camber - it would have been a bit of a cluster if cars started stacking-up in there. first thing i was ever taught at the track - "drive as fast as you can afford".
anyway, sorry for thread hijack. GF says my car sounds like a cartoon car - if a kid could make a race car, that's what it would sound like. not sure if that was meant as praise, but i'll take it. very happy with the 996 tune.
Old 01-03-2017, 09:43 AM   #63
jaykay's Avatar
Both feet in mother %&*$#@ and keep them there. That's what I used to say until I had a spin where I went both feet in hard and the abs came on and let me roll backwards across the track just like that even though I was mashing the brake as hard as I could. However it looked like the corvette just released the brakes and rolled back... It is a peeve of mine...
I have not experienced this....so ABS active roll backwards? Yikes! Do you drop the clutch nowadays? In my younger days I have had big ABS cut out switches on my car such that I could shut it down if it started to get me in trouble
I am thinking I have never had this as in all my spins I have managed to use brakes to keep a fairly straight and keep forward momentum once things have snapped around.....been a while though for me. This excludes my Jeep on 401 black ice event
986 00S
Old 01-03-2017, 10:56 AM   #64
steved0x's Avatar
Yes, here:
https://youtu.be/ex41Q8B_w8o
As soon as it goes and I know I'm not going to recover I got both feet in, clutch and brake. And I am hard on the brake. Watch the car leisurely [edit: watching it again it is not so leisurely, it is really rolling fast] roll back across the track, inside the car I can hear (and feel) the ABS clicking like mad. I guess I should have let off and reapplied the brakes? Also I have added a new step to "In for a spin, both feet in" and that is to center the wheel so I don't curve back around across the track if my braking is unsuccessful.
Old 01-03-2017, 01:28 PM   #65
Porsche9's Avatar
Yes, here:
Would applying the handbrake as you come close to being stopped prevent rolling back?
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 01-03-2017, 01:49 PM   #66
steved0x's Avatar
Maybe but I doubt I could successfully pull that off... I think pulsing the brake pedal once to maybe "reset" the ABS when the car switched from rolling forwards to rolling backwards would probably work better. Although it all happens so fast...
Old 01-03-2017, 02:42 PM   #67
Porsche9's Avatar
It does happen fast that's for sure. With the Miata running into the Corvette I was watching and thinking "pull the hand brake" but when you are in the situation and the world spinning it not always easy to think clearly and react accordingly. It usually has to be practiced and almost automatic.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
