Old 11-07-2013, 09:31 AM   #1
JAAY's Avatar
DOF is here!
Just arrived. Bearing going in the freezer.
Old 11-07-2013, 12:48 PM   #2
Nice! Let us know how the install goes and post some pic's!
Old 11-07-2013, 01:20 PM   #3
How long do u think it will take u to install,seriously considering installing one myself,fairly mechanical.
I don,t need to change bearing just install the DOF on an 06 Boxster S. Any special tools i would need other than the standard stuff.
moresquirt is offline   Reply With Quote
Old 11-07-2013, 02:42 PM   #4
Theoretical propagandist
Eric G's Avatar
Lots of pictures as this is going to be really interesting! Missed seeing you this summer when I was back there, we need to set up a time next year!
Old 11-07-2013, 03:10 PM   #5
JAAY's Avatar
Pics to come. Eric - definately next time.
Old 11-10-2013, 11:57 AM   #6
JAAY's Avatar
A quick update. I haven't had any time to work on the DOF much. I just installed the new steel dual row bearing. I must say it went in quite easy with out freezing it. Next is to pit the clip on it and get the grinder out and make the necessary adjustments to fit the new flange. I'll go snap a pic of the new bearing in the car.
Old 11-10-2013, 01:58 PM   #7
rp17's Avatar
Subscribed!
Old 11-11-2013, 06:06 PM   #8
JAAY's Avatar
I only get about 45 mins here and there. Tonight I put in the bearing clip, made the notch for the dof and installed the dof. I used some permatex to make a tight seal, I nicked the gasket surface and didn't want to risk a leak. Lock righted the center nit and torqued it to its spec of 11ftlbs. Torqued the flange bolts also with the new bolts to 7.5 ftlbs.
Old 11-11-2013, 06:09 PM   #9
JAAY's Avatar
I notched it out slowly with a dremel, which worked very well. I smoothed it all out when done with a grinding stone.
Old 11-12-2013, 08:06 AM   #10
JAAY's Avatar
Next step is to thread in the fitting into the dof. I thought I trimmed back enough bell housing but I didn't. Instead of unseating it and removing it I purchased a 5/16 24pitch Allen head plug from the hardware store so I can put that in its place and remove a little more material with out the threat of shavings getting into the dof.
Old 11-12-2013, 12:20 PM   #11
JAAY's Avatar
Grinding complete, fitting fitted, tensioners re torqued and cam lock and crank pulley lock removed.
Old 11-12-2013, 03:27 PM   #12
Nicework!!
Old 11-12-2013, 04:27 PM   #13
ppbon's Avatar
You're almost there!
Good job.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
Old 11-12-2013, 04:38 PM   #14
Beginner
Jamesp's Avatar
Why is the case bolt above the IMS flange removed?
Old 11-12-2013, 06:29 PM   #15
JAAY's Avatar
They are updated bolts. I figured I would update them while I was in there.
Old 11-13-2013, 11:53 AM   #16
JAAY's Avatar
New name for the dof. Damn Oil Feed. I have a 987 airbox and let me tell you it's a pain in the you know what to get to the oil feed plug on the head. I'm not taking out the airbox so I now need to run to the hardware store to buy the one tool I seem to be missing, a 3/8 swivel.
Old 11-14-2013, 08:13 AM   #17
JAAY's Avatar
The manual doesn't tell you that the plug is either a 5.5mm Allen head or a 6mm. Mine was a 6mm. I finally was able to pull it and get the new fitting in with an assortment of extensions and a swivel.
Old 11-14-2013, 09:57 AM   #18
FYI you can just drill a hole for the oil line rather than grinding one out. I test fitted my DOF cover and marked where the hole needed to go. Then I started with a small drill bit and worked my way up to a 5/8" bit in the end. Start to finish was maybe 30 minutes for me using this method. I think it's also a little less mess.
I see you got a package with only one cam plug in it. I e-mailed Mike at TuneRS about this and he's going to start including two cam plugs in the future.
One hint on the oil feed - thread the hose onto the oil feed plug first and get it most of the way tight, but not fully tight. Then put the oil feed adapter in the head. It should still rotate fine with the hose a little loose and you can get it tight. Then put the final tightening on the oil hose line. It can be pretty tricky to get the oil hose on the oil feed adapter once it's already in place. Putting the oil line on first makes it a much easier job - at least it did for me.
Kirk Bristol
Old 11-14-2013, 10:04 AM   #19
JAAY's Avatar
Drilling a hole would have been nice. I am up to just tightening up the oil line on both ends. They are threaded already with no big deal. Thanks for all the advise though. It is a easy job to do as long as you are not afraid to get dirty and make a mess. I'm just hoping for no leaks after all is done. This was the first time I, myself have done a rear main seal and the DOF. I'm pretty confident it should all be ok though.
Old 11-14-2013, 02:03 PM   #20
Ah, okay. I had one heck of a time with my 996 threading up the hose at the head, but access there is completely different on a Boxster. Once I figured out the trick I shared though I got it done quickly...
Kirk
