Old 11-11-2013, 06:06 PM   #8
JAAY's Avatar
I only get about 45 mins here and there. Tonight I put in the bearing clip, made the notch for the dof and installed the dof. I used some permatex to make a tight seal, I nicked the gasket surface and didn't want to risk a leak. Lock righted the center nit and torqued it to its spec of 11ftlbs. Torqued the flange bolts also with the new bolts to 7.5 ftlbs.
JAAY is offline   Reply With Quote
