Old 06-06-2011, 07:28 PM   #12
Crazy Austrian
harryrcb's Avatar
Originally Posted by BYprodriver
These look good to me, shift to neutral to check alignment, but if they are connected I would not change adjustment. Easy to remove console as all panels pull off easily & ashtray comes out after removing T10 torx screw in bottom. Check pelicanparts.com tech info section for good trans repair pics.
Northing is good here. the bottom outer cable is more than half way out of it's holder and the top one is completely out of the holder. It will not shift unless the outer cable is mounted correctly.
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
