Originally Posted by rdougan
Ok, bought a jack today and took a look:
It seems that the bottom most one is out of place. I tried quickly putting it back in, but it is awkward to get at. Any tips?
Also, Is it as simple as that? The top most one seems to have a loose washer as well. Issue?
These look good to me, shift to neutral to check alignment, but if they are connected I would not change adjustment. Easy to remove console as all panels pull off easily & ashtray comes out after removing T10 torx screw in bottom. Check pelicanparts.com tech info section for good trans repair pics.
