06-25-2012, 11:00 AM
#21
Just ordered mine. Will take about a week to get here. $50 for shipping tho which is outrageous even for Canada.
It is still about half the price of anywhere else though which is nice
06-25-2012, 02:02 PM
#22
Do I complete you guys or what !!
06-26-2012, 02:30 AM
#23
Ex Esso kid
Something about this post makes me want to put an entire box of testosterone patches in the mail to you.
06-26-2012, 04:35 AM
#24
Leave my testicles out of it !
06-27-2012, 10:56 AM
#25
Got the sensor next day which was surprising and it did level out the RPM's however I am still getting the idle hunt for a few seconds when I come to a stop. I am not sure if that's the sensor or something else with the engine. Will be investigating through the forum. Thanks again for the link Johnny
06-27-2012, 10:58 AM
#26
Sometimes it can take a little time for the ecu to re-adapt .
06-27-2012, 05:00 PM
#27
JD to the rescue! JD to the rescue! Go Johnny Danger! Go Johnny Danger!
Sung, of course, to the tune of Jim Dandy.
2000 S
Metallic Black over Boxster Red
6-speed
06-27-2012, 05:08 PM
#28
Just think of me as being a life force !
06-28-2012, 07:26 AM
#29
Noticed when I was in there doing the MAF that the oil filler tube is leaking oil on the engine. Wiped the source of the leak with a paper towel and sure enough, fresh oil. Looks like that leak could be the source of my persisting fluctuation. It did get better with the new MAF that your link took me to. In the shop today getting Low temp thermostat, fuel filter and now oil filler tube done. Should be running like a dream after that.:dance:
09-07-2012, 09:13 AM
#30
Still having issues and the oil filler tube that was replaced is still leaking but the source is where the two tubes come together. I tried taking off the clip and moving them closer together but I don't want to risk pulling it out of where each tube is seated. I will be taking it back to the shop, once again  , to be fixed. I am getting so tired of this **********
09-13-2012, 03:08 PM
#31
How often have you guys had to replace your MAF? I just replaced mine about a year and a half ago and I'm throwing the 1128/1130 combo again. After I replaced it the first time, these codes were nonexistent. Now they're creeping up again every other drive.
I read somewhere that the TIP Boxsters use a different battery than the Group 48 that is listed for the car. Another forumer said this was causing low voltage readings which would cause those two codes? Does this sound accurate? I just replaced my battery last week with an Interstate Group 48, and was just curious.
Would really like to know how often I can expect to be replacing this damn MAF...
09-13-2012, 07:33 PM
#32
Tip must use Group 94R. It may or may not clear the codes.
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
09-14-2012, 01:06 PM
#33
Jaak I just saw your other thread on the battery issue for TIPs. I actually just replaced the battery 3 weeks ago with a 48 and just got off the phone with the place. They said they'd swap it out for free if I could bring in paperwork that showed that my car calls for a 94R instead (their system shows the 48). Is this documented anywhere that the Tip uses the 94?
09-16-2012, 06:01 AM
#35
Generally speaking, I'm not one to recommend buying generic or aftermarket "clones" without knowing the actual origins of the part. However, I got lucky about a year ago when I was about to purchase a genuine Bosch MAF sensor, wherein the seller informed me about an aftermarket version they carried as well - that was a fraction of the cost of the Bosch sensor. Is it turned out, the sensor proved to be identical in every way to the oem part, and it has since performed flawlessly. Nevertheless, I view my experience in this particular case as being an exception to the rule. And, that's why I decided to report on it.
09-18-2012, 07:35 AM
#36
Just wanted to add to this thread..I was pulling 4 codes on my 98 (Cant recall exactly what they were now but I'll dig them up again, P1124, P1126, P1128 and P1130 seems to ring a bell? Let me confirm again though) After lots of reading on here and other forums, I figured a faulty MAF was the culprit. Tried to clean it a couple times with no luck..check engine would come back on within 20 kms.
I picked up one of the ebay MAF's. The MAF came from Carparts Wholesale and it cost me $48.00 plus $2.50 for shipping to Ontario Canada. I figured at that price, it was worth a shot. ($400 were my local quotes) I called to confirm and cross reference part numbers (both the bosche and porsch numbers) to make sure it was the right one for my 98.
Arrived yesterday morning, at first glance it looks identical, only missing the "bosche" logo. Threw it in yesterday afternoon and all good so far (crossing fingers) Drove around last night for a couple hours (150 kms give or take, highway, through town, trying to get all driving conditions) enjoying the last few sunny mild days and it's working perfectly!
No check engine light so far, much smoother acceleration (above 5k where there was a very slight hesitation) drives like a new car again!
09-22-2012, 11:51 AM
#37
Gents,
My MAF is at end of life. I got the one from Buy Auto Parts. For the S model it was 109. Installed and drove for over 100 miles with quite a few stops and slowdowns. Car is very sluggish. No idle or hunting RPM issues, no CEL. When accelerating its like it doesnt have any power at all. I dont hear the heavenly sound of the exhaust which I used to over 4000 rpm. Disconnected and drove it and it seems it's back to life again.
Bad sensor maybe? It is under warranty but I would like to be sure before I return it for replacement. Thanks.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
09-22-2012, 12:24 PM
#38
Originally Posted by Bala
Gents,
It's hard know, but my experience has always been that an MAF sensor either works or it doesn't. In which case, if the sensor is not working properly then it would trigger a cel.
09-22-2012, 01:02 PM
#39
No CEL so far. But the car feels like it's pulling a semi.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
09-22-2012, 02:20 PM
#40
Actually, I have experienced what I would call a noticeable decline in performance when an MAF sensor is on it's way out. But, this occurs during a very short "window" of time just before the sensor fails and triggers a cel. Maybe you should consider returning it for a replacement and see what happens .
