Old 09-20-2010, 04:00 AM   #19
did a bit more work this weekend; mostly just organizing & cleaning. the corrosion on the block was a bit excessive; i tried an acid etch (alumiprep 33) followed by alodine to halt the process & protect the metal. it looks a LOT better, but not nearly so good as it would if i could have dipped it instead.
LOADS of parts are on the way, & many have already shown up. my clutch is here, IMS arrived, a batch of goodies from Pelican (motor mounts = $104!), etc.
the real meat should start showing up from Sunset late this week. this will be o-rings, gaskets, seals, secondary air stuff, etc.
next weekend, i'll start building up the new motor & pulling all the goods off the old one.
i did find one interesting deformity on the block. it looks like someone tried to repair the case by weldind on some extra aluminum. if this is factory work, it sure is sloppy......
look at the case bolt flange:
the left one is normal. the right one, not so much....
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
