I tell you what would be cool, if you can tap into the k-line and get info like RPM and Throttle position, is some code that would receive requests in CAN OBDII protocol, send the request to the K-line, and return it back in CAN OBDII format.
I have one a RaceCapture/Track data capture device, and one of its features is that it can take CAN OBDII requests and translate then into various pre-CAN OBDII protocols. This lets me get things like RPM and Throttle position. However, the refresh rate on this is pretty slow, I get around 2 RPM readings per second, and 2 Throttle position readings per second.
Edit: forgot to include the links
Here is the adapter that translates the CAN OBDII requests into older OBDII formats:
https://www.autosportlabs.com/product/obdii-legacy-adapter/
Here is the device I have that uses this adapter:
https://www.autosportlabs.com/product/racecapture/
Here is a short clip, the first column is time in seconds, 2nd column is RPM, and 3rd column is Throttle Position (range 1-100)
Code:
Time RPM TPS
359.409 4666 31
359.611 4709 31
359.809 4709 31
360.007 4709 35
360.21 4789 35
360.61 4789 53
360.789 4852 53
360.809 4852 53
360.989 4852 100
361.009 4852 100
361.19 4852 100
361.21 4852 100
361.61 4975 100
361.788 4975 100
361.808 4975 100
362.007 5060 100
362.208 5060 100
362.611 5175 100
362.811 5175 100
363.012 5175 100
363.611 5278 100
363.812 5391 100
363.988 5391 100
364.008 5391 100
364.21 5391 100
364.59 5500 100
364.61 5500 100
364.81 5592 100
365.011 5592 100
365.209 5592 100
365.41 5656 100
365.61 5656 100
365.81 5656 100
366.011 5774 100
366.211 5774 100
366.39 5774 100
366.41 5774 100
366.611 5886 100
366.811 5886 100
367.011 5886 100
367.211 5974 100
367.61 5974 100
367.811 6077 100
368.011 6077 100
368.191 6077 16
368.211 6077 16
368.59 5904 16
368.61 5904 16
368.81 5904 11
369.009 5423 11
369.19 5423 10
369.21 5423 10
369.592 4912 10
369.612 4912 10
Each RPM reading lasts for 5 or 6 updates and the TPS seems to be a little faster, maybe every 4 updates.
From capturing logs with my Durametric, I know I can get about 10 discrete pieces of data per second, like this (this is a pull in 2nd gear)
Code:
Time RPM Speed in MPH
14:07:08.1607752 2805 25.5
14:07:08.3697872 2838 26.1
14:07:08.5797992 2959 28.0
14:07:08.8008118 3101 29.2
14:07:09.0218245 3264 30.5
14:07:09.2408370 3422 32.3
14:07:09.4498489 3571 33.6
14:07:09.6608610 3721 35.4
14:07:09.8708730 3880 36.7
14:07:10.0808850 4028 37.9
14:07:10.2998976 4183 39.8
14:07:10.5099096 4328 41.0
14:07:10.7199216 4490 42.3
14:07:10.9299336 4652 44.1
14:07:11.1399456 4821 46.0
14:07:11.3499576 4993 47.2
14:07:11.5529692 5137 48.5
14:07:11.7599811 5301 50.3
14:07:11.9709931 5470 51.6
14:07:12.1860054 5626 53.4
14:07:12.4050180 5811 55.3
14:07:12.6300308 5975 56.6
14:07:12.8470433 6147 58.4
I would *love* to be able to get that type of update rate from the car in a way that I could send it to me data logger.
From what I understand, CAN is more of watching a stream of data rather than query/response like older OBDII protocols?
Wish 1 - an OBDII dongle that could query the k-line and give the fast refresh rate that I know the car is capable of. You could probably sell a decent amount of these
All 986, 996, and maybe even early 9x7, could use this.
Wish 2 - a port somewhere that would simulate tapping into the CAN line on the newer cars and stream selected performance data, even if it was *only* RPM and TPS, since the other stuff you can get from OBDII like
intake air temp etc... doesn't require a fast rate.
Since you are in there anyway...
Since you have access to all that,
