03-05-2015, 05:13 PM
#41
Good, thinking I forgot the wipers have power for return to rest.
03-14-2015, 11:25 AM
#42
running lights
found the power to the wiper (black/white)
03-15-2015, 03:40 PM
#43
I like the look of your LED DRLs, can you advise where you bought them?
Barkinfool
'02 Boxster S
05-07-2015, 05:19 AM
#44
Don't know where he got his, but this outfit in China has a large selection....I have ordered various things from them and they ship quickly and have good quality stuff, in my experience.
The name's Ian....now a former owner.....sold my 2000 Speed Yellow Base to its new owner in Nova Scotia.
05-07-2015, 05:50 AM
#45
What does it look like when the lights are off? I always wondered if a very low profile "strip" type of light could go in that position.
05-08-2015, 08:52 AM
#46
do you have any photos and or more detailed instructions on how you made the wiring connection to the wipe wiring?
06-29-2015, 08:15 PM
#47
Halogen vs LED
I originally did this using the amber LEDs . While visible, it wasn't as noticeable as I originally wanted.
Then, I changed out the LEDs for 50 watt Yellow Halogen H 7 bulb. Brighter, more eye catching.
06-29-2015, 09:16 PM
#48
There Is No Substitute.
I had rubber strip LED's installed with adhesive, however, a lot of the LED's went bad, I suspect from being hit by small rocks/debris. I pulled them off, and having be waiting until I find a very low profile LED that has a hard plastic clear front. I really like the look of what ls1ac is using, hopefully he can share where he found them.
When I did my install, I ran a cable to the 12V switched power under the dash (through the firewall) and grounded the lights to a bolt inside the front trunk. It worked perfectly until the LED's went bad. Regardless of which power source you use, I would recommend installing a M/F plug when you run the wiring so that you can easily remove your front bumper.
07-23-2015, 07:34 AM
#49
I have had the same experience with the white LED's. Is there any issue with the Halogen H7 burning the fog light lens when left on all of the time?
07-23-2015, 05:48 PM
#50
The LEDs are much cooler than the standard bulb so there is almost no heat. I have had mine in for at least 6 years without a problem.
08-04-2015, 01:29 PM
#51
I am kinda lost.
So I put the fuse tap where the lights go?? On the h7 bulb or relay place. Sorry for dumb question really like this mod and have everything to do it, expect I do not understand the instructions /:
08-04-2015, 02:04 PM
#52
On the slippery slope
Originally Posted by Mr.JonathanLanda
I am kinda lost.
Maybe you should swallow it and go see a doctor
2004 996 Targa Tip
Instructor - San Diego region
08-04-2015, 02:17 PM
#53
I made that comment Because the other forum member said "he threw up in his throat" regarding my comment.
If that offended you, I apologize.
But you are older than me, you should know better.
You should be here for help and support. Not bashing ppl.
Your comment is completely irrelevant to the question I asked. If you have nothing good to say, don't say anything.
You started a thread to completely attack me and it backfired. So stop. Get on with your life and be a positive example for younger folks.
08-04-2015, 03:20 PM
#54
You need to learn some manners. Age has nothing to do with it. BigJake is much younger than you and never has the attitude you do.
You find it OK to make a snide remark to a member and then when the same thing is pushed back, you get your panties in a twist. If you want people to help you, try to not come off as such a smartass newbe
maybe you should do a little searching and actually read the threads. Post #1 is very clear to where the fuse tap goes, it's on the relay
Actually I did not start a thread to attack you and it is similar to one from another member. I specifically did not respond to your thread because i did not want to rain on your parade until you made an uncalled for comment. There is also nothing to backfire and in any case there not everyone shares your belief that your need to do lot of changes right off the bat. Drive the car, enjoy the car, become the car , ommm.
there have been a lot of new owners recently both here and on other forum that are doing all kinds of mods to their cars before they even drive them a bit and see what may or may not be necessary.
You want to put a bunch of crap on your car because you have more money than brains, go right ahead. BTW, the sprint booster is a waste of money and most will agree K&N filters are not such a great idea for a Boxster
Do what ever cosmetic changes you want, everyone here has an opinion and we all know what opinions are, mine included.
I see you are in San Diego, so why don't you chill out a bit, enjoy your car for a bit and then figure out what needs to be done with it.
The biggest performance mod you can do is Driver Education. I can guarantee that unless you are Patrick Long's clone, you are not driving the car anywhere near its capability. Join our local PCA chapter and you will find a lot of great friendly and helpful people. In fact there is an Autocross this Sunday at Qualcomm. Its probubly too late for you to register as a newbe, but come on down, see a lot of P-cars and meet some cool people. Hell I'll even buy you a beer afterwards
2004 996 Targa Tip
08-04-2015, 03:34 PM
#55
maybe you should do a little searching and actually read the threads. Post #1 is very clear rt where the fuse tap goes, it on the relay
 🏻 praises for the good info, that's why I am here to know what mods work and what not.
07-18-2016, 08:54 AM
#56
I gave up on this hack, unable to find reliable LED bulbs.
07-18-2016, 10:20 AM
#57
The ones I put in 18 months and 20k miles ago are working fine
2004 996 Targa Tip
07-18-2016, 12:55 PM
#58
Donate them to a museum right away.
When this flaky LED tech disappear completely in 5 years it would be nice to have at least two that still works
07-19-2016, 10:22 AM
#59
These look great but it is hard to choose one because there are so many questionable quality ones on Amazon. Still running well? How did you fasten them?
07-19-2016, 10:37 AM
#60
1999 Boxster, Ocean Blue Metallic-grey top.
LN IMS dual row-, Ben's short shift kit
Reason: link
| Thread Tools |
| Display Modes |
Linear Mode
