Old 07-19-2016, 11:56 AM   #61
2002 Boxster S
I've had these in my 986 since January 2014. They're a bit too blue for my taste (5000K), but I can't seem to find any at 4500K, so I live with the color difference.
2009 Carrera S cabrio
ex-2002 Boxster S, Arctic Silver, Aerokit II
silver-S is offline   Reply With Quote
Old 07-19-2016, 01:41 PM   #62
Nine8Six's Avatar
If really you get bothered by the blue'ish then look into hacking them open and install a filter. Often just adding a 0.3mm thick diffuser (white frost) makes them turn yellow'ish. I'd say at about 3.5k~4k.
Intensity diminish however -15~20%
filters are sourced from photography studio supplies
Old 07-19-2016, 02:05 PM   #63
On the slippery slope
JayG's Avatar
Originally Posted by pilut2 View Post
those look like the ones I have
2004 996 Targa Tip
Instructor - San Diego region
Old 08-29-2016, 11:05 PM   #64
itskenallen's Avatar
Any pics of the leds in the fog light housing?
Sent from my SM-G928F
itskenallen is offline   Reply With Quote
Old 11-25-2016, 06:27 PM   #65
neilw's Avatar
Just picked up my 1999 Boxster and like the idea of the drl's in the fog lights. The Radio shack part numbers provided by OP are no longer listed, but I see autozone has fuse taps. Without pulling my covers off, can someone tell me if it's the simple flat blade fuse taps? Dorman Fuse and Accessories 85606- ReadReviews onDorman #85606
Big rains coming, so Boxster under wraps for a few days. Like to pick up the parts in the meantime. Thanks.
UPDATE:
Found another thread with pics: http://986forum.com/forums/general-discussions/54796-drl-hack-pics.html
1999 Boxster 986 Black/Savanna Tip
2013 Boxster 981 Racing Yellow/Black PDQ
neilw is offline   Reply With Quote
Old 12-02-2016, 06:50 PM   #66
Thank you so much for this hack. I successfully performed this hack today.
Below are some pic I like to contribute to the thread.
knite75 is offline   Reply With Quote
Old 12-02-2016, 08:32 PM   #67
neilw's Avatar
Here's the finished look using LED's with the parking lights on.
Old 12-20-2016, 01:03 PM   #68
redciv1's Avatar
Are the LED's to keep the temps down on the lens cover?
Also, has anyone incorporated Auto headlights that would work in conjunction with this hack?
Anything special needed for the LEDs or direct replacement.
redciv1 is offline   Reply With Quote
Old 12-20-2016, 01:21 PM   #69
JayG's Avatar
The LEDS are lower heat and last longer than H7's
What auto headlights?
2004 996 Targa Tip
Old 12-20-2016, 03:04 PM   #70
neilw's Avatar
In some people's opinion, the LEDs look more modern and may be seen better in the daytime. Also no need to worry about burning out, unless the LED's are poor quality to start with.
There are direct replacement LED's for the fog lights. I got these on amazon based on a recommendation on this forum.
Old 01-09-2017, 10:10 AM   #71
Lew
So Blessed!
Lew's Avatar
Regarding the DRL Hack. If I remember correctly, I read that someone did the hack and had been using the original Fog Light Bulbs for a long time without causing lense damage. Anyone recall this, or know the post? I tried a search using certain words, but no luck. I was successful doing the hack, but I unplugged the wire from the fuse until I know for sure the OEM bulbs will not cause damage to the lens. My thoughts are Porsche would not put a bulb in place that would burn a lens. Something else I read that was not answered. If doing the hack, what happens if you select the Fog Lights with the switch?
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
Old 01-09-2017, 10:51 AM   #72
neilw's Avatar
If you pull the fog light switch on, nothing happens since the "fog lights" are already on. Note that the DRL do go off when you switch on the brights.
Old 01-09-2017, 10:56 AM   #73
Originally Posted by Lew View Post
Regarding the DRL Hack. If I remember correctly, I read that someone did the hack and had been using the original Fog Light Bulbs for a long time without causing lens damage. Anyone recall this, or know the post? I tried a search using certain words, but no luck. I was successful doing the hack, but I unplugged the wire from the fuse until I know for sure the OEM bulbs will not cause damage to the lens. My thoughts are Porsche would not put a bulb in place that would burn a lens. Something else I read that was not answered. If doing the hack, what happens if you select the Fog Lights with the switch?
Your thoughts are incorrect. Every exterior light fixture can and has been burned/melted by stock bulbs. Do not use halogen bulbs as DRL.
Old 02-07-2017, 07:47 AM   #74
Lew
So Blessed!
Lew's Avatar
I finally changed out the OEM fog light bulb's to the H7 LED's that some are using. I did raise the Fog Lights up 10 turns on the adjustment screws. They look so much better than the OEM's.
Old 02-07-2017, 11:30 AM   #75
Silly question about this, does the hack throw any codes/warning lights etc??
That boy's got the Devil in him.
Justin327 is offline   Reply With Quote
Old 02-07-2017, 02:13 PM   #76
JayG's Avatar
no, nope, nada, no way
I did it over 2.5 years ago and not one single issue
2004 996 Targa Tip
Old 02-14-2017, 10:03 AM   #77
awesome thanks!
Old 02-14-2017, 10:50 AM   #78
Lew
So Blessed!
Lew's Avatar
There is supposed to be a hack that will let one use the low beams as DRL's....
Old 02-14-2017, 11:21 AM   #79
JayG's Avatar
There is, its called twisting the light switch to turn your low beams on
It would involve a relay and more wiring.
The Fogs work fine as DRLs
2004 996 Targa Tip
Old 02-14-2017, 12:18 PM   #80
Lew
So Blessed!
Lew's Avatar
I removed my Post
