07-19-2017, 08:07 AM
#81
Originally Posted by Lemming
My wife, the artist of the family, is responsible for the livery. She wants to add a splash of red or orange to match the rear lights and possibly do one set of wheels in the same color.
I like how you painted the front grills grey. Your wife is right: orange side view mirrors and maybe the lower rocker panels and even the front grills and side grills would be nice. I personally like the wheels in orange as well😀
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
07-19-2017, 09:08 AM
#82
Actually, all grills are the exact same color, but look quite different because they are recessed within the black body.
My last race car was orange!
Tim
1998 986 (3.2L and 6-speed transmission added)
1999 986 (SPB)
1999 986 (parts car)
2001 986 S (parts car)
07-24-2017, 07:20 AM
#83
Great test weekend at Road Atlanta, although it was stinking HOT! One good thing about the heat (95 with lots of humidity, 135 track temp), I found out that my cooling system works very well, water temps never got above 190.
This was my third test weekend in the car, first two at Barber. Because I was bouncing off the bump stops at Barber, I raised the car slightly before the weekend. During the first two trips I didn't understand all this talk about corner entry oversteer, that was until I went into T1 at full speed trying to trail brake deep as I always did in my 944 race cars. First step was to decrease compression in the rear, which helped a little but not enough, so I dropped the rear ride height and that helped quite a bit. I also had to chance my driving method through the corner to get back on the gas sooner to plant the rear. Will have to continue to work on this.
I did take one wild ride on Saturday coming out of T1, I closed the gap on a GT3 far too quickly at trackout and had to either lift, go off track, or hit him. I lifted, putting me into a spin and off track, doing a fantastic 360 and ending up to the left of T2. Luckily nothing was hit, but I did tear up some of the underbody plastic pieces. Data shows I went started the spin at 89 mph. Most of my driving buds were parked sitting at T1 watching the entire episode, took a bunch of crap for that one.
Tim
1999 986 (SPB)
09-06-2017, 05:16 PM
#84
Been working hard to get the car ready for the NOLA PCA race in 9 days. I've been going through the checklists and the car is ready to pass race inspection. Did another corner balance today and then to a friends this weekend to align. The most work that I have to do is to replace brakes and drums on my trailer this weekend.
Tim
1999 986 (SPB)
11-21-2017, 03:16 PM
#85
Been awhile since I updated.
NOLA race was fun. Car was not handling well at all in the first race, it was bouncing off the front bump stops making the car hard to handle. Finished 5/8 in SPB. After the race I cranked the compression to nearly full stiff. Then we lined up for the second race and it dumped huge amounts of rain on us as we were sitting on grid (everyone was on slicks). We ran 3-4 laps without the race officially starting and then were brought in as the track was under water. It was nearly impossible to go straight at 20mph without hydroplaning. Race was moved to Sunday morning. The points race went well, car handled much better and I managed a 3/8 finish. About 1 hour after the sprint we started our 90 minute enduro. First 15 minutes were fine, but then the car started oversteering badly and I spent the rest of the race fighting the car. Turns out that the front sway bar bolt had broken and therefore was running with no front bar. It was interesting to say the least. After I was back home going through the car I also found a broken left rear shock mount, that is now fixed.
Engine and gearbox worked well and I'm happy with the results.
Pick below is from the enduro, making the inside pass into T13.
Tim
1999 986 (SPB)
11-21-2017, 11:29 PM
#86
Nice results for a new entry!
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
11-22-2017, 05:35 AM
#87
Yes, looking forward to reading more about it as you get it sorted.
11-22-2017, 03:15 PM
#88
Last weekend I was at Barber racing with PBOC. All issues with the suspension were fixed and I did not do any further mods to the car. There were no other SPB cars at the race and my only hope for fun was a friend in an SP3 car. Unfortunately, he had car trouble for the enduro, so I had no good wheel to wheel action. I did push the car hard for the 60 minutes and it ran well with no issues. I was looking forward to the sprint races on Sunday as my friend fixed his car. Qualified with a respectable 1:44.7, which is well under the current SPB record at Barber. First race went well, but my friend spun early, one GTS2 car was on my tail for a few laps before I pulled away. Second race was a blast as it was very close with the sp3 car for the first few laps. He got me on the start, and I got by after a few laps. Once passed I started pulling away by 4-5 seconds, then the dreaded double yellow came out. Once we got back racing, the sp3 car got me coming out of the hairpin and going into T7 (more power) and with two laps to go, I was unable to get him back (but it was close). Great fun. Best part was that when I pulled away, I set my personal best lap of 1:44.3.
So far the car has been great. I really need to get it on the dyno and see what kind of power it is putting down, will do that in the next couple of weeks.
Pic for attention.
Tim
1999 986 (SPB)
12-04-2017, 12:16 PM
#89
Decided to add a splash of color to the car.
Tim
1999 986 (SPB)
12-24-2017, 10:24 AM
#90
There was a good sale going on, so I decided to replace my short drop links with long drops links. I kept having problem with binding on the shorter ones.
Tim
1999 986 (SPB)
12-24-2017, 10:42 AM
#91
I had the same problem and it went away with the long drop links. Keep the updates coming!
01-07-2018, 06:53 AM
#92
Dropped 20 lbs from the car yesterday.
Tim
1999 986 (SPB)
01-30-2018, 01:20 PM
#93
Wiring Removal
Great Thread - I'm where you where at about page 2 of thread. As a non-wiring guru (good at cutting, not so good at understanding diagrams or soldering) any recommendations on how to attack what's under the dash? I figure that there must be 20-30 pounds of wires, but it will be far easier to do before the cage goes in...
Thoughts?
01-31-2018, 05:00 AM
#94
If I had to do it over again, I would leave the fuse box and relays in their original position, moving them to the passenger side was a pain.
Print out the wiring diagrams and make sure you know what wire you are cutting. I had multiple components off of my engine when I started the wiring and therefore could not start the car after cutting wires to make sure I didn't mess up.
20-30 lbs of wire seems optimistic - 10 to 15 possibly.
There's a good post either on this board or on rennlist which shows you how to get the alarm module down to 8 wires.
Take your time and don't be in a hurry.
Tim
1999 986 (SPB)
02-09-2018, 12:47 PM
#95
Headed to the Barber with Chin this weekend. Looks like lots of rain, but warm (mid 60's) all weekend. A good chance to get my wet setup dialed in.
Pic for attention - Spy vs Spy.
Tim
1999 986 (SPB)
02-12-2018, 07:04 AM
#96
Found an oil leak on top of the engine, cannot tell where it is coming from. Oil is pooled on both sides of the case, so my day ended early on Saturday. Ran the white car on Sunday.
Tim
1999 986 (SPB)
02-26-2018, 03:36 PM
#97
Finally got around to editing a race video from NOLA last fall. Terrible start, but stayed out of the way as a couple of drivers spun half way through the first lap. Managed to go from 12 to 8 overall and 3rd in SPB (out of 8). Had to laugh when I saw in the latest PCA Club Racing News that I got the hard charger award for this sprint. Thanks again for guys for spinning and making it a bit easier for me.
https://youtu.be/S39WFFob51o
Tim
1999 986 (SPB)
02-26-2018, 03:51 PM
#98
Check your connections to the AOS. I had one of the snap in fittings not quite snap in all the way after replacing my starter. I had oil pooled on the engine and dripping down on the ground....
02-26-2018, 05:07 PM
#99
Nice driving... finally go by the maroon car... hounding him paid off.
If all goes well at CoTa this weekend -- I plan to head to NoLa.
Mike
02-27-2018, 05:11 AM
#100
I pulled everything off the top of the engine. Replaced the seals on the oil fill and the dipstick tubes. Resealed the two plugs for the secondary air system that I removed. New crush washer on the oil level/pressure sender. The upper AOS hose appeared to be on and tight and I did not see oil around the fittings. Checked the lower AOS hose for cracks but did not see any.
I'm still not sure where the oil was coming from, hopefully it is now fixed. Going to do one day at Barber with Tracks Unlimited to make sure that it's fixed before the tow down to the NOLA race.
Tim
1999 986 (SPB)
| Thread Tools |
| Display Modes |
Linear Mode
