Old 02-27-2018, 05:11 AM   #100
Lemming
Lemming's Avatar
Originally Posted by rastta View Post
Check your connections to the AOS. I had one of the snap in fittings not quite snap in all the way after replacing my starter. I had oil pooled on the engine and dripping down on the ground....
I pulled everything off the top of the engine. Replaced the seals on the oil fill and the dipstick tubes. Resealed the two plugs for the secondary air system that I removed. New crush washer on the oil level/pressure sender. The upper AOS hose appeared to be on and tight and I did not see oil around the fittings. Checked the lower AOS hose for cracks but did not see any.
I'm still not sure where the oil was coming from, hopefully it is now fixed. Going to do one day at Barber with Tracks Unlimited to make sure that it's fixed before the tow down to the NOLA race.
Tim
1998 986 (3.2L and 6-speed transmission added)
1999 986 (SPB)
1999 986 (parts car)
2001 986 S (parts car)
Lemming is offline   Reply With Quote
