Old 02-28-2017, 06:35 AM   #801
seningen's Avatar
The process is right here on the car...
Very impressive ---
I would like to know what those shims are made out of -- I need to diversify my portfolio.
Mike
mike@lonestarrpm.com
Old 02-28-2017, 06:59 AM   #802
JayG's Avatar
They are made from unobtanium
Old 02-28-2017, 08:56 AM   #803
You and me both! Someone is making a financial killing.
For those following along at home, here is what we're talking about. These are the prices for each shim - remember you need one for each side. I think that my car has 3 shims per side to get the -3.6 deg neg camber.
Old 02-28-2017, 09:10 AM   #804
Originally Posted by jakeru View Post
Hey Tom, nice repair work. You might want to consider mounting the helper/tender spring up top, with main spring down below. The reason is to reduce unsprung weight.
Thanks, I never though of this and will discuss with the shop.
Doesn't it take about that long to dial-in the alignment settings?
The plan is to set the car back at the same alignment spec's that it had before the accident. The net handling as a result of combining the old alignment specs with the changes from the repair plus the mix of new parts and old parts might not be exactly the same (in terms of handling characteristics), but it should be close enough to race it for a weekend and then adjust as necessary for the next race.
Hope everything gets pulled straight so you can get the right alignment characteristics!
There doesn't appear to be any damage to the chassis so the car didn't need any pulling (per se) but the front suspension subframe is being replaced. This should provide a completely straight and sold foundation to ensure a good and repeatable alignment.
At least, those are our assumptions! We'll see how it all works out soon enough.
Old 02-28-2017, 01:20 PM   #805
JayG's Avatar
Just remember:
All Constants are Variables
Old 03-01-2017, 06:44 AM   #806
Good job Tom, its coming together nicely
bkovac is offline   Reply With Quote
Old 03-02-2017, 09:06 PM   #807
I dropped by the shop today and the Boxster was ..... gone!
This was a good thing since that meant that it was driven (!!!) down the street to the body shop to have the fender, bumper cover, and rear quarter damage repaired.
The downside was that as work on the suspension was completed a few more parts were ultimately found to need replacement like the right front hub/upright which looked ok to the naked eye but was misaligned once all of the suspension components were installed and a rough alignment done.
Also, we decided to go ahead and replace the right rear wheel bearing since the right rear wheel took a hit hard enough to crack the rear suspension subframe meaning that the wheel bearing took a huge thrust force which it was not designed to take. So we might as well replace it now.
Still looks like the car should be ready next week - worst case is that everything gets done except final paint of the front bumper cover which can be done after the race weekend.
I also expect some teething problems after replacing this many parts, so I don't expect to be in the front of the field next weekend. The goal for next weekend is to get back on the track and complete all of the sessions. There will likely be a few things that might still need adjustment or tweaking to get the car back to full competitive form.
Old 03-02-2017, 09:31 PM   #808
List of major parts replaced:
  • Right front fender
  • Right front fender inner liner
  • Right front headlight assembly
  • Front bumper cover
  • Left and right front side marker lights
  • Left and right radiators
  • Left and right radiator air ducts
  • Left and right radiator mounting brackets
  • Upper radiator hose
  • PSS9 coil over shock absorber
  • Front upper shock mount
  • Front wheel carrier/hub
  • 996 GT-3 adjustable lower control arm
  • 996 GT-3 adjustable lower control arm shims
  • Adjustable drop link (long style)
  • Front track arm
  • Right inner & outer tie rods
  • Front suspension subframe (cross member)
  • Fuel filler tube
  • Right rear suspension/transmission subframe
  • Rear wheel bearing
  • Right rear taillight assembly
  • Right front wheel (8.5x17)
  • Right rear wheel (8.5x17)
  • Four tires (Toyo RR 255/40/17)
Old 03-03-2017, 09:41 AM   #809
seningen's Avatar
  • Front track arm
  • Fuel filler tube
The tires and those shims probably cost you the most :-)
But the grin you'll have when you grid up next week will have been worth it.
I would have been down 6 months!
Mike
Old 03-03-2017, 10:52 AM   #810
Still driving it up?
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
Old 03-03-2017, 11:24 AM   #811
Absolutely yes!
Old 03-06-2017, 02:46 PM   #812
Here is video of the start of Race #1 from two weeks ago. I started 6th and moved up to 3rd on first lap.
Later in the race, Kovac/#318 and I swapped 3rd a couple of times but then he held onto it and I finished 4th. Overall, it was a good race for me.
You'll see that I now have the rear view camera displayed as picture-in-picture so you can see the action behind as well.
Be sure to manually click for 1080p high def to get the best experience (the video really looks great).
Old 03-06-2017, 04:04 PM   #813
steved0x's Avatar
I love these videos with commentary, great job!
Old 03-06-2017, 06:42 PM   #814
gotta keep that, we both passed Hainer
Old 03-06-2017, 10:27 PM   #815
I know. I thought his car broke.
Old 03-07-2017, 09:06 AM   #816
Yeah, the old sugar in the gas tank works every time, hey Branimir?
Great to hear you're up and ready for this weekend, Tom. Looking forward to joining you chase Anders.
NigelT is offline   Reply With Quote
Old 03-07-2017, 03:54 PM   #817
Tom & I are looking forward to you and Anders starting in the back
Old 03-09-2017, 08:35 PM   #818
Ready for racing this weekend!
Everything is complete except the final paint and replacement of a few stickers (which will be done next week). Also, I'll install the matching front headlight and a pair of clear side marker lights.
The car feels great - front suspension and steering is actually tighter than before. I guess that should be expected after replacing that many components.
Big thanks to Brad Keegan and Tyson Schmidt of Pro Motorsports in Burbank, CA for the high quality and FAST repair!
Driving up to Buttonwillow in the morning for practice tomorrow. Racing Sat and Sun.
Old 03-09-2017, 10:09 PM   #819
JayG's Avatar
Chump car LOL
Best of luck to you Tom
I'm heading out to Chuckwalla in the morning for the weekend
Have fun at Buttonwillow
Old 03-10-2017, 05:55 AM   #820
rastta's Avatar
Awesome - have fun!
rastta is offline   Reply With Quote
