Old 03-03-2017, 09:41 AM   #809
seningen
seningen's Avatar
List of major parts replaced:
  • Right front fender
  • Right front fender inner liner
  • Right front headlight assembly
  • Front bumper cover
  • Left and right front side marker lights
  • Left and right radiators
  • Left and right radiator air ducts
  • Left and right radiator mounting brackets
  • Upper radiator hose
  • PSS9 coil over shock absorber
  • Front upper shock mount
  • Front wheel carrier/hub
  • 996 GT-3 adjustable lower control arm
  • 996 GT-3 adjustable lower control arm shims
  • Adjustable drop link (long style)
  • Front track arm
  • Right inner & outer tie rods
  • Front suspension subframe (cross member)
  • Fuel filler tube
  • Right rear suspension/transmission subframe
  • Rear wheel bearing
  • Right rear taillight assembly
  • Right front wheel (8.5x17)
  • Right rear wheel (8.5x17)
  • Four tires (Toyo RR 255/40/17)
The tires and those shims probably cost you the most :-)
But the grin you'll have when you grid up next week will have been worth it.
I would have been down 6 months!
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
