04-19-2012, 07:20 AM
Racing Alignment on stock suspension
Guys,
Is it worth adjusting the stock suspension for racing? I've been told there is not a lot that can be done and it's not worth spending the money. The only addition I have is gembella lowering springs. Everything else is stock.
I have hoosier R6 tires and I'm under the impression that they're not good with stock camber.
Please chime in.
04-19-2012, 08:09 AM
What are your alignment settings now?
You will be camber challenged with the stock suspension and R6s, but to say there not good is a stretch. By running non optimal camber you will just wear them out faster and you will not have the maximum grip they a capable of.
Are you running the PCA HPDE at Miller May 5th?
04-19-2012, 09:14 AM
I have the sheet in my car, it's not with me now. From what I remember my alignment was done for best tire wear and due to my lowering springs they couldn't have it exactly 0. Again, should I have Dave Strong Porsche realign my car more race oriented. Is it worth paying 169?
Yes, I plan on going to the PCA HPDE. My appointment today is for alignment and a tech inspection.
04-19-2012, 11:12 AM
I haven't done it yet but I am going to change the alignment for the track. I'm going to go with as much negative camber as the car will allow in the front, with the toe set at zero. In the back, I'm going to go with 1/2 degree less camber than the front, and the toe set at 1/16. Hopefully this will dial out some of the understeer that is engineered into these cars and help it turn quicker.
Also, the recommended tire pressure of 29/36 induces lots of understeer. Just by running the same pressures all around, or a slightly lower rear pressure than the front also helps with the understeer.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
04-19-2012, 11:24 AM
Thanks. I'm going to suggest that to the dealer when I go in today.
I'm running 275 35 18s in the rear and 245 35 18s in the front.
04-19-2012, 01:25 PM
Yes, its definitely worth doing a track alignment even with the stock suspension. Here is the series of events that I have followed over the past 16 months (new is in bold). As Topless said, its not a slippery slope, its a cliff!
1. Stock suspension, standard stock alignment, street tires. Fine for beginning track driver. As I got better/faster, I had extreme wear on the outside 1/3 of front tires.
2. Stock suspension, track alignment yielding max -1.2 deg camber in front, street tires. Much improved handling and improved grip. But again as I got better/faster, I had extreme wear on the outside 1/3 of front tires.
3. Stock suspension, track alignment yielding -1.2 deg camber in front, Nitto NT-01 race tires. Much improved grip due to the stickier tires. but the camber alignment limit casued premature/extreme wear on the outside 1/3 of front tires. Forum members (noteably Topless and Brad) predicted this would happen and they were correct.
4. Stock suspension, adustable GT-3 lower control arms, track alignment yielding -2.25 deg camber in front, Nitto NT-01 race tires. Started out with even tire wear. but as I got faster, I still have too much wear on the outside 1/3 of front and rear tires.
Next month....
5. PSS9 upgrade with adjustable sway bars, adustable GT-3 lower control arms, track alignment yielding -2.5 to -3.0 deg camber in front, Toyo RA-1 race tires. This is the Spec Box setup and I expect (hope for) better handling, more grip, and fairly even tire wear.
To the OP: sounds like you're about where I was around Step 3 so the track alignment will definitely improve things. Then prepare yourself for Step 4 or Step 5...
04-19-2012, 02:46 PM
Next month....
Ah, the slippery slope. You are definitely hitting the track pipe hard. Good for you.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
04-19-2012, 07:48 PM
I'm an addict!
04-19-2012, 03:11 PM
Next month....
This is too good! I really appreciate the info.
Adjusting the stock suspension -as you clearly know- was well worth it. The car felt completely different driving home from the dealership. It has a lot more bite in the corners.
Final camber for the LF was -1.4 and RF -1.4.
Rears came in at LR at -2.4 and RR -2.6.
Who knows maybe the GT3 control arms are next.
04-19-2012, 04:24 PM
Why are you running so much negative camber in the rear? Unless I am mistaken, to dial out understeer, the idea is to get the rear camber less than the front.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
04-19-2012, 04:37 PM
To be honest they didn't do what I asked or they simply misunderstood me. In any case I'm happy with it, feels great.
I have lowering springs, that might be why I got -1.4 out of the stock suspension. Everything apart from the springs is stock.
04-19-2012, 05:11 PM
You should be fine with those camber settings.
What did you set toe at?
I run -3.0 and 0" toe front and -2.0 1/16" toe in rear. I do have GT3 arms.
I signed up today for the DE and the time trial. Also I can point you to a reliable SLC place that can do alignments for a lot less than $169.
04-19-2012, 04:28 PM
You were able to get -1.4 out of the stock suspension? Wow, thats a lot I hope i can get that much when I change mine.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
