Old 08-28-2021, 10:33 AM   #1
vkmotorsports's Avatar
Coolant leaks out from here
Hello
I have a 2001 Boxster S with ~143,000 miles on it.
For the last 2 months (and I have barely been driving this car more than 10-20 miles a week during those months) i have had a serious coolant leak.
Most of the coolant leaks out as soon as the engine starts running from the middle bottom of the car (picture attached). The coolant tank then drops to much below the minimum level.
When I was jacking up the car as well some of the coolant poured out but I think that was just residue from the earlier leaks collecting there.
This problem did not exist in May, but has started since June. At first I thought the issue with low coolant was due to excess heat and evaporation. But that is not the case as now I can see a leak happen as soon as the engine starts.
I don't know what has changed. I have never done anything to the car since May besides getting an alignment at a Firestone while getting new tires installed by them.
I have also never opened up the undercarriage of the car or got work done there. I have done the oil changes myself and the brake pad changes myself.
How do I figure out what the problem with the coolant leak is ? Is it some damage caused during the alignment ? I cannot prove that is what has happened at all, as it is just conjecture on my part.
What is the best way to go about diagnosing the problem.
Please advise.
vkmotorsports is offline   Reply With Quote
Old 08-28-2021, 10:43 AM   #2
Keith Newby's Avatar
I think it may be time to take to consider replacing the water pump.
Keith Newby is offline   Reply With Quote
Old 08-28-2021, 10:57 AM   #3
is water pump failure causing the leak or is the process of fixing the leak an opportunity to also replace the water pump ?
Old 08-28-2021, 11:10 AM   #4
First thing to do is a visual inspection of the suspected area of the leak.
If you find nothing obvious (like a leaking hose).
Then get a coolant system pressure tester.
Places like Harbour freight have them for a reasonable price.
You can test just about any coolant system with them as well as the coolant cap.
With the test kit is it easy to find leaks in coolant systems.
People will say change this or change that. That is Poor way to do things.
Find the cause of the problem then fix the problem.
Old 08-28-2021, 12:57 PM   #5
I went and purchased the Harbor Freight radiator pressure test kit and will try it out.
Agree that I want to find the cause first before trying out solutions.
Thank you.
Old 08-28-2021, 01:28 PM   #6
First thing to do is to STOP driving the car
Next - remove belly pans
Next - Look to see where coolant is coming from
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 08-28-2021, 02:01 PM   #7
Thank you.
From what I can tell in your picture I am looking at the the area where the aluminum pan (brace) and the plastic under body trays meet.
Remove that plastic under body tray and you should see where a number of coolant hoses meet up.
Then top your coolant system off with distilled water and pressurize the system with your tester. You should have no problem finding your leak..
Once it is repaired then us the tester to again pressurize the system so you can make sure everything is ok.
Old 08-28-2021, 04:44 PM   #8
+1 to blue and Stl's comments. Remove belly pans, pressurize the system, localize the leak. DO NOT DRIVE UNTIL IT'S FIXED.
Old 08-28-2021, 05:00 PM   #9
VK,
I should have mentioned this in my first post.
Another item that is a common coolant system problem is the plastic coolant fill tank in the rear trunk.
They develop hairline cracks with age.
You should remove the carpet and the sub floor in the trunk.
Strip everything out Down to bare metal.
Then when you pressurize the coolant system you can check the plastic coolant tank as well.
Keep me posted..... if you need to replace the coolant tank I can give you a few pointers.
Old 08-29-2021, 12:11 PM   #10
VK,
Thank you all. blue62, I filled up the tank all the way, I did the pressure test on the tank as per the Bentley manual using the harbor freight kit and it did not show any sign of leaks in the tank area. At least the tank is not cracked and was still full after the pressure test.
I flipped up the bleeder valve locking clip a couple of times and there were no leaks and drips initially when I started and moved the car back and forth in my garage to driveway. I drove the car for 0.5 mile locally, and saw no leaks or drips at all. Coolant level looked full in the tank exactly as it looked when I had filled it up
Drove it for 5 miles after waiting 30 min, and making sure there were no drips or leaks.
After the 5 mile drive is when I noticed that the dripping began again in 3 different spots which coincide with hose placements most likely - 2 in the middle of the car and one near the front of the car towards the radiator.
I am waiting for the car to cool down to check the coolant level after the dripping has stopped. Most likely the hoses are failing when the car gets hot.
Then I will redo the pressure test and look for hose leaks again.
I am contemplating that in a hot condition the hoses may be expanding to cause dripping/leaking and when cold the car does not drip. Most likely the hoses have gone bad or the clamps have become loose.
Last edited by vkmotorsports; 08-29-2021 at 12:13 PM. Reason: Improved sentence formation.
Old 08-29-2021, 01:02 PM   #11
piper6909's Avatar
From your description, I doubt the hoses are your problem. That's generally not how hoses go bad. I'd suspect your water pump. More specifically, the shaft seal.
2010 Subaru Forester
Old 08-29-2021, 01:12 PM   #12
Thank you piper6909.
1) When you say "water pump" is that the same as "coolant pump" in the Bentley manual ?
2) Is the "shaft seal" same as "crankshaft seal" ? that repair work is beyond my capability at the moment.
What would the approximate cost of repair be for this at an independent repair shop ?
Old 08-29-2021, 01:21 PM   #13
piper6909's Avatar
Yes to 1, no to 2.
Sorry if I wasn't clear. The coolant pump (water pump, as it's often called) has a seal around the pulley shaft. It is not a replacable item, though. You'd have to replace the entire pump.
I suspect that's where your leak is coming from. If you haven't done so already, remove the belly pans like stl-986 wrote, and take a look aroung the water pump to be sure.
Or you can probably remove the cover behind the seats and look from there, but I believe you'll get a better angle from underneath.
Old 08-29-2021, 01:23 PM   #14
piper6909's Avatar
Wait, did I read correctly that it's leaking in the front too?
Old 08-29-2021, 01:24 PM   #15
Yes to 1, no to 2.
I have run out of time today, but I will try it this week and get back to you all.
Thank you.
Old 08-29-2021, 01:37 PM   #16
you really just need to get it lifted in the air, remove the pans and the pressurize the system. That is the safest method to finding the leak. Otherwise have it towed to a shop and have them find it and fix it.
If you continue to drive the car you will end up causing more damage and then will be asking what it takes to remove & replace the engine.
With coolant leaks and major oil leaks you dont want to just keep running the car to find the issue, it will be worse for your wallet.
Yes, you could have a host that is failing when hot, but pressurizing the system will show hose issues also, without the engine getting hot & overheating....which WILL happen if you continue to drive it or run the engine.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 08-29-2021, 01:39 PM   #17
sort of. there was drips from the front body part area, and then also from the plastic shield cover area. It could just be the same leak flowing forward since my driveway slopes downward and the car nose was along that slope.
I did not take a picture but next time i will take a picture to mark the exact location. Either way I have to lift the car up fully and take out the plastic shields and examine stuff.
Old 08-29-2021, 01:55 PM   #18
VK,
Sounds like it could be the water (coolant) pump.
Once you get it in the air and remove the body under panels you will be able to get eyes on it.
The coolant at the front could be from coolant running along a hose or on the body under panels.
I have looked at your blog.
I see your not afraid of something like this.
you will be able to do this repair no problem.
You just need to get "eyes on" the leak so you know if it is hoses or water pump.
Once you identify the problem you will have no issues.
Old 08-29-2021, 02:38 PM   #19
Leak from the front kind of changes direction to some degree. It very well could be either of the radiators or the center one since you have an S.
Your right though, getting the covers off and eyes on it will help.
One thing you could do to help, get the covers off, then lay cardboard out under the entire car. pressurize the system. The cardboard will act as an extra set of eyes and help you pinpoint the location.
Getting it on level ground though will be necessary obviously
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 08-29-2021, 04:27 PM   #20
piper6909's Avatar
In that case, yes, it could very well be rolling toward the front of the car with the driveway slope. Otherwise, although highly unlikely, it could be one of the tubes running to the front of the car.
Tags
coolant , coolant leak
