Old 08-29-2021, 01:12 PM   #12
vkmotorsports
vkmotorsports's Avatar
From your description, I doubt the hoses are your problem. That's generally not how hoses go bad. I'd suspect your water pump. More specifically, the shaft seal.
Thank you piper6909.
1) When you say "water pump" is that the same as "coolant pump" in the Bentley manual ?
2) Is the "shaft seal" same as "crankshaft seal" ? that repair work is beyond my capability at the moment.
What would the approximate cost of repair be for this at an independent repair shop ?
vkmotorsports is offline   Reply With Quote
