Old 08-29-2021, 01:24 PM   #15
vkmotorsports
vkmotorsports's Avatar
Yes to 1, no to 2.
I suspect that's where your leak is coming from. If you haven't done so already, remove the belly pans like stl-986 wrote, and take a look aroung the water pump to be sure.
Or you can probably remove the cover behind the seats and look from there, but I believe you'll get a better angle from underneath.
I have run out of time today, but I will try it this week and get back to you all.
Thank you.
vkmotorsports is offline   Reply With Quote
