Old 03-08-2019, 04:41 PM   #21
Originally Posted by PaulE View Post
You need the right potatoes to make the best french fries too.
CoA or not, I'd still insist on a PPI Pre Potato Inspection...
"Cool Prius!"
- Nobody
Old 03-08-2019, 06:08 PM   #22
By someone PCA certified (Potato Club of America)!
Old 03-08-2019, 06:32 PM   #23
I be liking Fries too, But without the proper recipe or BEST way to cook them ! your fries could be suckie. and Nobody likes suckie FF,Still Not sure who was first or who makes the best one's..is there a solution,??
flmont is online now   Reply With Quote
Old 03-08-2019, 07:20 PM   #24
On the slippery slope
JayG's Avatar
AMERICAN fries boys, None of those damn frenchy things
2004 996 Targa Tip
Instructor - San Diego region
Old 03-08-2019, 08:28 PM   #25
The Radium King's Avatar
you mean freedom fries, yes?
Old 03-08-2019, 08:57 PM   #26
How can you possibly have a conversation about the quality of french fries without discussing the type of oil?
alynch is offline   Reply With Quote
Old 03-08-2019, 09:02 PM   #27
Who's askin'?
maytag's Avatar
Easy there.... look below at my first post in- this thread.
Ok... I referred to "grease", which when heated becomes "oil". Oil type is INCREDIBLY important to fries.
Old 03-09-2019, 02:52 AM   #28
BOOTLEG's Avatar
When I was in the decision mode, I called LN to check on the re-use question. They confirmed it can be re-used which pushed me to the Solution.
BOOTLEG is offline   Reply With Quote
Old 03-09-2019, 06:51 AM   #29
"50 Years of 550 Spyder"
10/10ths's Avatar
Simple....
......Air Fryer Freedom Fries.
Wins every time.
No oil at all.
So much winning!
Old 03-09-2019, 07:32 AM   #30
2003 S, Arctic Silver, M6
paulofto's Avatar
I also believe the IMS Solution is touted as the 'Final solution'
Yikes, never use that term when talking about anything from Germany
Old 03-09-2019, 12:11 PM   #31
jaykay's Avatar
The theory on the DOF is the lack of lubrication causes heat build up, leading to galling and failure. As the dual row has twice the contact area, the heat build up in the bearing should be both faster and to a higher temp, which should be leading to its failure sooner than the single row. But that is not what happens in the real world, were single rows fail at a rate near ten times that of dual rows.
Yes all good thoughts but I am not sure a dual row would produce more heat, or critical heat levels because there are more points of contact. Friction is driven by “normal” loading of one element against another and in the case of a dual row one can argue the loading is split between two bearing assemblies. Normal loads are lower at each yielding lower friction forces perhaps below critical levels.
Having said all of this I am of the opinion that poor brearing design is a main factor and that no amount of lubrication in a rolling element bearing will circumvent an overload condition
986 00S
Old 03-10-2019, 10:04 AM   #32
thom4782's Avatar
Having sold my 986, this is probably my last comment on the IMS question.
Most people look at this issue in the wrong way. If all IMS alternatives have similar longevities, which is a big assumption in itself, the substantive issue then is what happens when they begin to fail.
Any bearing that fails in a mode that allows the engine to jump timing is inferior to one that doesn't.
My view is simple. Failing plain bearings cause less damage than failing roller bearings than failing ball bearings. On this metric, the IMS Solution wins.
So the question turns on does one spend more money up front (the Solution) to avoid higher replacement costs later (the alternatives)
'87 951
'01S 986 (Sold after 16 years ownership)
'78 924 (carburated; sold when moving to CA)
Old 03-10-2019, 12:34 PM   #33
B6T
Why Porsche ever thought using a grease filled sealed bearing (lubricated for life, ha ha) was a good idea, along with a 15,000 mile oil change interval by the way, will always be a mystery to me.
This is my interpretation of it...
Option A:
Provide a means of supplying lubricating oil to the plain bearing arrangement at the back of the engine by increasing the complexity/weight of the engine case casting, the machining cost to gun-drill all the oil passages, and the potential failures related to poor machining/casting from this additional oil passage, in addition to the more complicated/costly bearing components. RND was probably the second group to evaluate the oil-fed plain bearing, Porsche being the first.
Or...
Option B:
Install a sealed bearing that doesn't require lubrication.
People seem to think that Porsche doesn't know what they're doing. At the design stage for this engine, all relevant data would have suggested that the sealed 6204 bearing was the best option based on reliability and cost (cost being the most important factor in automotive design).
B6T is offline   Reply With Quote
Old 03-11-2019, 09:13 PM   #34
It’s actually the opposite, since the bearing wear is twice as fast in the single row because of the double load compared to the dual row. So the single row starts pitting much sooner. DOF would make sense if the failure was the result of lack of lubrication. But that’s not the case in a bearing that’s swimming in oil all the time.
But that's actually the reasoning behind the DOF; the bearing, even though it's submerged in oil at rest, is NOT submerged in oil at all when the engine is running, contrary to popular belief. Here's a visual explanation from Pedro:
https://www.youtube.com/watch?v=qj06dqBk0to
Javi Cooper is offline   Reply With Quote
Old 03-12-2019, 09:14 AM   #35
SC-986's Avatar
Certainly not an expert here and all I can offer is my own personal experience. I purchased my ‘04 S about 1 1/2 years ago. One of the selling points was that the IMSB was upgraded in 2014 at 87,000 miles. The car now has 114,000 miles on the odometer. The DOF option was used and at the time of purchase I hadn’t researched the major differences between the DOF and LN’s offerings.
Fast forward to today and my ‘02 base at 168,000 mi. recently threw a cam deviation code. It is in the shop for further diagnosis and so I have spent a good bit of time researching the different IMSB upgrade options in the event that is the problem.
It seems the naysayers of the DOF system claim that where the oil is drawn from the engine to lubricate the IMSB is problematic in that it could be contaminated with debris or cause oil pressure problems on bank 2.
To date with nearly 30,000 mi. on the DOF system I have not experienced any oil pressure issues and I drive it pretty hard through the twisties of the Blue Ridge Mtns.
The drain plug magnet and filter do not have any ferrous material on or in them.
Most people will not write about a thing if it is working as designed, they only write about it when it fails. In my research I ran across (3) occurrences where LN’s ceramic retrofit bearing failed between 30,000 - 40,000 miles resulting in catastrophic engine failure. I found (1) occurrence of a DOF system concern where there was some valve train noise on bank 2 and when the oil feed was disconnected the noise went away - no failures per se.
On my ‘02 base if it requires an IMSB replacement, because of the high mileage, I will probably go with the DOF option. The IMS Solution is the gold standard and if the car had lower mileage I would opt for that. With the DOF system I can take the 1000.00 saved over the Solution and apply it to future engine repairs.
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
SC-986 is online now   Reply With Quote
Old 03-12-2019, 01:35 PM   #36
Yeah, I came across this video. Still, I don`t think it justifies the need for DOF. The IMS is submerged almost all the way to the top of the shaft when your level is at the max sign, and is submerged around half way up when it`s at the min level. So, the inner ring (that is fixed) is always submerged in oil that will carry excessive amount of oil onto the balls and the outer ring. Centrifugal force has nothing to do with this because the inner ring is not spinning. Ball bearings do not require DOF. There are motorcycle engines with ball bearings operating at much higher rpm and temperature that an IMSB and they are totally fine with submerged or splashed oil lubrication or even oil mist in 2-stroke engines. But you don`t have to go that far, look at the ball bearings in your transmission, they are lubricated by splashing oil, and they don`t fall apart, even if the input shaft is spinning at much higher rpm than the IMSB.
Old 03-12-2019, 06:12 PM   #37
SC-986's Avatar
If this premise is correct then why did the Porsche engineers specify a sealed grease filled bearing and not a bearing with the outer seal removed?
Old 03-12-2019, 08:16 PM   #38
No clue. The idea of a grease-filled bearing would not be entirely wrong if the shaft wasn`t sealed. Since it`s sealed, the pressure that builds up inside the tube in normal operating temperature forces the grease out of the bearing. When cooling down the opposite happens, vacuum in the tube results in seeping oil into the bearing. Eventually the grease gets replaced by engine oil, that`s what we see when we open a genuine bearing. I think if the IMS was depressurized this wouldn`t happen. Not sure though which is better...
Old 03-12-2019, 09:03 PM   #39
elgyqc's Avatar
My understanding is that the advantage of the original sealed bearing is that misc. metal shavings in the oil (the stuff we see in cut open oil filters) does not get into the bearings and that the original grease is a better lubricant. As mentioned the pressure changes, with time, wash the grease out and the seals prevent an adequate supply of new clean oil. So if you remove the outer seal on an original bearing (or a replacement for that matter) the bearing will be well lubricated by oil, but it could be affected by metal bits circulating in the oil. But than again if there is enough metal in the oil to affect the bearing you likely have another serious problem. Just my $.02 worth.
Grant
Old 03-13-2019, 07:33 AM   #40
I`ve heard this theory but it does not make much sense to me. In a normally functioning engine there`s no metal bits circulating in the engine. Debris is constantly being filtered out of the oil by the oil filter. If metal particles get to the oil there`s an engine faiilure coming soon anyway and a sealed bearing won`t make a difference. Larger particles, typically broken timing chain rail pieces that can`t go through the oil pick up mesh are too large to get to the IMS because there`s no space.
