05-12-2017, 05:10 AM
IMS tell tale
I purchased a 02 986. do not know if the IMS bearing issue was resolved on the car.
I did my first oil change. cut the old oil filter open. absolutely no metal fillings whatsoever!
Is the IMS issue been replaced?
05-12-2017, 05:18 AM
Not entirely sure why people keep going on about this, if you had nothing in the filter then you have nothing to worry about.
Now go and drive it.
05-12-2017, 05:58 AM
Without records to prove it has been done, you are making a baseless assumption, which can prove disastrous (yours is a single row bearing engine, which has shown the highest probability for failures)..
05-12-2017, 06:00 AM
Simple: the number of single row bearing owners that have taken similar advice and ended up paying the price for it...........
05-12-2017, 06:27 AM
And the fact that he (I presume) just recently bought the car. All things "new" that may or may not have a serious known problem are something to be aware of. Reassurance is a good thing for a new owner, especially on a used car. I know that's where I have been (but it's getting better.)
Dave
2002 Boxster S Tiptronic. Lapis Blue/Grey leather/upgraded Metropol top (glass rear window.) Still learning new things all the time about this awesome car!
05-12-2017, 06:37 AM
Figures please.......
05-12-2017, 07:13 AM
Count me as one of those who at 100k miles fell for "if it's good at 30k it's good at 230k" myth/lie and regrets it to this day
05-12-2017, 07:39 AM
What's the anecdotal failure rate?
2001 Boxster S, Guards Red
05-12-2017, 07:47 AM
This is what i'd like to know and every time i ask it gets ignored.
05-12-2017, 08:14 AM
When last compiled several years ago in the class action, it was greater than 10% failure rate. As more have failed since, it is reasonable to assume that number would now be higher, but there is no way to know by how much.
05-12-2017, 08:15 AM
You have your answer.
05-12-2017, 08:16 AM
If it is a stick, it will need a clutch and RMS sometime- so better now while it is a simple ,relatively inexpensive job. Add a few 'while you are in there' jobs and you'll probably have a great car for years to come.It is like Insurance -if you have it, you're unlikely to need it.If you don't have it.....
05-12-2017, 08:47 AM
I am amazed there are people who still don't believe it is an issue.
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
05-12-2017, 08:48 AM
But if it's a Tip you can't piggy back this project on a clutch job. And it costs more to pull a Tip as well. So much for buying a Tip with the belief that "at least I'll never have to bother with a clutch change"
Carlos
05-12-2017, 10:10 AM
I am No. 1348
Quite simply, this is the same issue we have been facing with other cars for decades with timing belts. It's a maintenance item.
Either you gamble and don't replace it, or prevent engine disruption by being proactive and replacing it before it fails.
05-12-2017, 10:23 AM
While I would love it to be non-existent as an issue, I'm taking the maintenance tack: short oil change intervals (monitor for debris), change bearing with clutch and RMS .... only challenge is that historically clutches seem to last me longer than 20 000 miles ... so ....
05-12-2017, 10:42 AM
What does the clutch lasting 20K miles have to do with anything?
05-12-2017, 11:20 AM
Only true for interference engines. For non-interference engines this is not a catastrohic issue, more of an inconvenience. Memories of a 1980 Volvo wagon which ate its timing belt at 30k miles and fortunately suffered no ill effects.
And the timing belt maintenance is in the owners manual when you buy a car. I haven't found the section in my manual where it specifies the interval for replacing the IMS.
Has Porsche ever come out and defined this service interval, or do they just let owners discover it on their own? I don't use the dealership for more than parts -- has anyone ever had a dealer recommend an IMS replacement proactively?
05-12-2017, 11:46 AM
The reason or that is that according to Porsche, you cannot change the IMS without taking the engine apart on any M96 or M97 engine, and as they do not let their techs take engines apart, you simply are billed for a factory replacement engine. Solves their problem, and yours, well, sort of anyway...........
05-12-2017, 11:59 AM
Learn something new every day: You can't change an IMS without taking the engine apart.
