Old 05-09-2017, 11:48 AM   #1
A sad day for my bank account...
Just heard back from my indy regarding my annual check and service: camshaft deviation angles are now very close to 6 degrees on both banks.
ugh.
Around $2k to replace both camshaft wear pads.
2000 2.7L base with 69,000 miles -- probably to be expected. Looks like I'll have to give up the champagne and caviar for awhile...
Need_for_speed is offline   Reply With Quote
Old 05-09-2017, 11:54 AM   #2
That's a bummer.
Having done this job myself recently, I think if I had to do it again I might pay $2k.
dsallean is offline   Reply With Quote
Old 05-09-2017, 12:28 PM   #3
I am No. 1348
algiorda's Avatar
I'm curious, what made you check your camshaft deviation in the first place? Is this really performed during annual check and service??? I never really heard of such a thing.
algiorda is offline   Reply With Quote
Old 05-09-2017, 12:36 PM   #4
Takes a few seconds extra with PIWIS/Durametric if it is already hooked up. Good PM check.
Next step is a "while you are in there" list to minimize future bank balance damage?
Old 05-09-2017, 03:49 PM   #5
There Is No Substitute.
rick3000's Avatar
Not trying to hijack the thread, but would would be considered good and bad cam deviations. I would like to check mine next time I hook up the Durametric.
Old 05-09-2017, 03:53 PM   #6
Artist, 986S tinkerer
NewArt's Avatar
Under 6 is çonsidered within spec.
Old 05-09-2017, 04:11 PM   #7
I asked my indie to check the values, knowing that I was probably pretty close. This is a wear item on these cars, and after around 60-65k miles, these pads just wear out. If you don't replace them, they'll eventually cause really big problems that are even more expensive to fix.
I am curious to know if replacing these pads was a part of the standard maintenance schedule. My guess is a lot of owners decided to trade the car in rather than do the job, passing the problem down to a second owner who either didn't know the problem existed, or was unwilling to spend the money, thus perpetuating the issue.
Oh well, this is a wonderful little sports car. I will never, ever get my money back out of it, unless you consider the miles of smiles when I drive it.
Old 05-09-2017, 04:52 PM   #8
Sorry to hear at only 69k miles? So, just out of curiosity and for future reference does anyone know if this can be done without pulling engine? Is this a job where you have to pull both bank cam covers? Will covers come off within car?
Lapister is offline   Reply With Quote
Old 05-09-2017, 04:52 PM   #9
07 Carrera S Cab
Boxtaboy's Avatar
Are you sure this is a common wear item? MarcW on Pedrosboard has over 300k miles on his 02 2.7L that he bought new, and I've never heard of him replacing the camshaft wear pads.
EDIT: Confirmed with MarcW that he has not had to replace his Camshaft wear pads. He's got over 310K miles on his 02 Box.
Old 05-09-2017, 05:02 PM   #10
Yes you can remove the cam covers with the engine in the car but it is a horrid job and you need cam holding tools and a tool for compressing the Actuator.
Unless you are very well equipped for this and have lots of time,patience ,and very skinny hands and research .I would not recommend it. Yes I have recently done it but as JFP astutely hinted when I started the job- it is like building a ship in a bottle. And you need 2 !
Old 05-10-2017, 03:39 AM   #11
Project Addicted
jcslocum's Avatar
Was there a thread on this??
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 05-10-2017, 08:39 AM   #12
Pelican cover it but with engine out.
Old 05-10-2017, 08:52 AM   #13
Make sure the engine has been for a really good run before checking the angles
What else needs to be done while ur in there? I was going to replace the chains
Old 05-10-2017, 08:56 AM   #14
steved0x's Avatar
Mine are around -6 (2000 Boxster S, 130K miles), I talked to some folks about getting it done, and one of them said to come see him when the CEL comes on, which I think (I may be recalling incorrectly) he said was at +-9. I check it from time to time and it has been holding steady over the 30K miles I have owned the car.
Old 05-10-2017, 08:59 AM   #15
Chains - that is an engine out job unless you want to try split links?
Old 05-11-2017, 08:12 AM   #16
the short chains come out with the actuator
Old 05-11-2017, 08:14 AM   #17
Of course they do. You have no choice with the cam-to-cam chain. The issue would be the IMS to cam chain.The clue is the phrase "split link"- only applies to the longer IMS to Cam chain.Just rebuilt all this stuff.
Old 05-12-2017, 09:57 AM   #18
I have had 3 M96 cars and never had an issue. All told close to 300k miles over all three. I had one engine rebuilt but that was for performance, as it had no issues at the time. It may be a wear item, not saying it isn't, but not sure why I haven't had the problem. I've had most of the known maintenance problems. No engine failures but I got IMS taken care of as soon as there was a fix
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is online now   Reply With Quote
Old 05-12-2017, 12:19 PM   #19
Wish I had your luck! Not sure why you haven't experienced any issues with these as well. There's actually been quite a bit posted on this forum and others about these wear pads, and not taking care of the issue gradually leads to a worsening list of problems. At some point, the cam deviations will lead to a CEL. If you continue to ignore the issue, the pads will wear completely through, and the chain starts to run directly on the timing chain tensioner ($1k each). At some point, maybe as your punching it down an on-ramp, or on the front straight on a DE day, the chain tensioner will not be able to keep up and the motor will slip timing.
My indie is a certified LN IMS installer, and he won't touch the car with a replacement IMS unless cam deviations have been corrected.
Old 05-12-2017, 12:34 PM   #20
I will check it with durametric for sure
My indie has never mentioned it. Lord
Knows I have done
Everything else
