Old 08-31-2016, 05:43 PM   #1
Couple more questions on rear lowering
1) the ball joint at the end of the toe arm on one side is stuck. I put a little liquid wrench on it and walked away. Any other tips. I am using a remover.
2) I started trying to remove the ball joint on the LCA and it wouldn't budge. Granted I did not go full fury on it because I wAs afraid of breaking the bolt. Can I use an impact wrench? Suggestions?
Thanks in advance.
David
DWBOX2000 is offline   Reply With Quote
