Old 09-04-2016, 07:17 AM   #22
steved0x
steved0x's Avatar
Is the inner eccentric bolt on the lca released? If not that is holding it up. That bolt clamps the rubber bushing, that's why the suspension has to be loaded into when tightening that bolt.
If that bolt is removed, see if the axle is hitting the exhaust. Removing the axle bolts on the transmission side may give you more room.
