Old 09-03-2016, 05:02 PM   #15
DWBOX2000
As Steve suggested, I am going to try and take the bolt off from the other side of the LCA (non ball joint side) Before I get there, I need to remove the bolt that's connects the trailing arm from the control arm. That nut does not want to budge. I put liquid wrench on it an will let it sit. Can I apply heat to the nuts to get them to expand a little so they might be easier to loosen. Any chance me snapping those bolts? That bolt is a 118 ft lb so will I need a pipe to loosen?
DWBOX2000 is offline   Reply With Quote
