Old 09-20-2015, 05:49 PM   #1
CHRISP357's Avatar
An I asking too much?
As I plan projects for my car's next hibernation, one wish keeps coming to mind. I want that burble sound from my exhaust upon deceleration. I don't want to buy a new exhaust system, encounter any CEL or cause any drone. Does this seem realistic?
CHRISP357 is offline   Reply With Quote
Old 09-20-2015, 06:05 PM   #2
Fintro11's Avatar
top speed secondary cat delete / muffler will do that for you i get lots of gurgle lots of head turns and lots of compliments
Old 09-20-2015, 08:39 PM   #3
No.
With that being said, Fintro proposed a reasonably affordable solution that doesn't have much drone but does require changing the exhaust system. Be aware that the exhaust will also be MUCH louder than stock - but it does sound very bad ass.
Old 09-20-2015, 08:55 PM   #4
Above is all true. I have Circuit Werks / Beluga, but same deal.
I got quite a bit more decel burble when I went to a 75mm TB and 997 plenum T, but exhaust was already in place, so I doubt it would have the same effect with stock exhaust.
Car is a 2.7 5-speed.
CraigM is offline   Reply With Quote
Old 09-20-2015, 09:23 PM   #5
I am my own mechanic....
Timco's Avatar
Can anyone point me to a video with sound of 'drone'?
I don't know exactly what that sound is, and it sounds like I wouldn't want that sound if I heard that sound.
'08 VW Touareg T-3 wife's car
Old 09-20-2015, 09:25 PM   #6
Top_Ramen's Avatar
Replace all cats with test pipes and run some race gas to richen the car up.
'99 Porsche Boxster 986 - weekend car
'04 BMW 645ci e63 - daily driver
'98 BMW 528i e39 - dog carrier
Top_Ramen is offline   Reply With Quote
Old 09-20-2015, 09:59 PM   #7
Porsche9's Avatar
Not sure "drone" can be captured in a recording. Part of it is a feeling/vibration you get from the sound in in ears. It's rather unpleasant.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 09-21-2015, 04:35 AM   #8
CHRISP357's Avatar
Sounds like what I'm looking for. No drone? What do you do about the O2 sensors left hanging?
Old 09-21-2015, 04:40 AM   #9
CHRISP357's Avatar
No.
My mistake, I wasn't clear enough. I meant that I don't want to change out the entire exhaust, headers, etc. but I'll give Fintros recommendation a try unless someone gives me a reason not to.
Old 09-21-2015, 07:11 AM   #10
steved0x's Avatar
If your 986 is a 2000-2004 all the O2 sensors are up in the exhaust manifold with the integrated cats. The 2nd cat is not monitored by the ODBII system and has no O2 sensors. I have the 2nd cat delete on my 2000 and it did nicely improve the sounds and there is some of the burbling like you describe. It is a little louder too but not extreme. I like it!
Steve
Old 10-10-2015, 08:59 PM   #11
CHRISP357's Avatar
Haven't located any Top speed test pipes. Circuit Werks just as good?
Old 10-10-2015, 09:09 PM   #12
Fintro11's Avatar
nope don't have to touch them, the drone can be annoying if you drive at low rpm's I drive at 3 - 4k rpms haven't had any drone
Old 10-10-2015, 09:20 PM   #14
Fintro11's Avatar
that last video skip to near the end to hear a 2015 gt3 fly by at about 200 km/h
Old 10-11-2015, 01:58 AM   #15
As far as I can tell. They are just pipes with bungs, just screwed the supplied plugs in with some thread locker, I believe you have to do the same with the Top Speed pipes (most are made to work on all 2.5/2.7/3.2, and 2.5's have the O2 sensors here).
Old 10-11-2015, 07:30 AM   #16
If you have a truck with four doors, roll down the rear windows partially and drive. You will get a horrible sound/vibration that is really hard to deal with. I can easily execute the drone sound in my xterra doing this.
2016 4Runner TEP
Muzzle of Bees is offline   Reply With Quote
Old 10-11-2015, 11:08 PM   #17
I guess they are just pipe joints with bungs, just attached the provided connects in with some line locker, I believe you have to do the same with the Top Rate pipes
SMS Marketing | Wordpress SMS Plugin | SMS Plugin | WP SMS Plugin
samandrewsone is offline   Reply With Quote
