09-14-2015, 04:01 AM
#21
Project Addicted
Pick up a laser thermometer and measure the temps at various places. There may be a bad sender involved and not other parts. Clean radiators is a good thing!
Jon
09-14-2015, 05:21 PM
#22
Originally Posted by Retroman1969
It should read on the low side of the 8?
Odd, both my 986's run in between the 8 and 0 when fully warmed up and can venture to the high side of the 0 in outside temps above 90 degrees. I've been told by two shops, the dealership, and even a few folks on here that it was a 'normal' operating range.
Side note: awhile back, my daily driver started reading about what the image in the first post shows (even a little higher) and it turned out that there was tons of debris sandwiched between the condensers and radiators. A proper cleaning as described above (removing bumper cover and separating the condensers from the radiators) brought it right back down.
I get the same results as Retroman. I was seeing to the right of the zero in mid 80's and 10,000 elevation this weekend while climbing up the passes.
09-17-2015, 04:16 PM
#23
I was driving yesterday the car and in the parking spot i saw how ALL coolant was leaking in the floor under, close to the back rear wheel. I immediately add more fluid but now when i tried to check from where was the leak i cant see nothing, the trunk is dry to... I stopped today in some chip service to ask the mechanic and he said what i have to change the head gasket, but i cant believed what is that!!!
Where i should check the leak? My car still hot, i already clean the radiators an the fans working properly..
09-17-2015, 04:25 PM
#24
I had the same thing happen to me. After driving for a while, the pressure would build up that it would start leaking. I tried to test it at home by letting it idle and it didn't leak. I stuck my hand under the coolant tank and felt liquid. I then changed the coolant tank and been good ever since.
#25
On the slippery slope
Stop driving the car
Check the water pump and hoses
you can get a look at it by pulling the carpet behind the seats and removing the access panel
http://www.pelicanparts.com/techarticles/Boxster_Tech/34-WATER-Thermostat_and_Pump/34-WATER-Thermostat_and_Pump.htm
probably not the head gasket
if its the water pump. its a reasonably easy DIY
Water pump, Thermostat, and coolant will cost you $350-400
Or you can have an indy shop do it, probubly add $300-400
What part of San Diego are you in? There are a lot of good shops that will not rip you off here
2004 996 Targa Tip
Instructor - San Diego region
09-17-2015, 04:32 PM
#26
Originally Posted by JayG
I'm from La Jolla/UTC
09-17-2015, 04:59 PM
#27
If your trunk is dry, its not likely to be the coolant tank
Was the tank empty?
The water pump is on the front of the engine on the passenger side, so a leak there could be by the tire
There are several plastic covers on the bottom that can redirect water from where it is leaking
If you remove the front one, its pretty easy, you will need a 10mm socket and a torx screwdriver. You may see where it is actually leaking from
Just be careful as the coolant will be hot and can burn you if the car is all warmed up
There is a very good indy just off Miramar road
Mirage Intl - Porsche parts and tuning
another excellent shop is
Black Forest Porsche/BMW/Mini | Your Dealer Alternative
You could also go to Porsche of San Diego on Miramar Rd. My guess it would cost you more there
I would see if you can figure out what is leaking and if it is the water pump and you have the time, DIY
Both shops are PCA members and may offer a PCA discount
Yo can join PCA for $46
2004 996 Targa Tip
09-17-2015, 05:06 PM
#28
Thank you!!
09-17-2015, 05:24 PM
#29
Beginner
That is certainly good advice. Both the water pump and the rear overflow hose dump water by the right rear tire. So, the pump could be leaking, or the car is getting really hot and the pressure is causing the coolant to dump out of the overflow. When I rebuilt my engine I had coolant blow out the rear overflow after initially filling it with coolant. That was likely due to air in the system. Has the coolant been changed or drained and replaced recently? Is the coolant green or pink?
2003 S manual
09-17-2015, 05:35 PM
#30
I bought the car few weeks ago i dont know. The coolant is green
09-17-2015, 05:38 PM
#31
Beginner
I bought the car few days ago i dont know. The coolant is green
So you likely have "coolant pudding" instead of coolant. The car uses pink coolant from the factory. Dumping in green prestone causes a chemical reaction that thickens the coolant making it unable to efficiently cool the car.
2003 S manual
09-17-2015, 05:41 PM
#32
Beginner
Anyone familiar with how to get a positive diagnosis and clean up this mess?
2003 S manual
09-17-2015, 05:51 PM
#33
That's not completely correct. There has also been green factory coolant. Porsche has also used yellow. The current color is pink
I just changed my WP and coolant and what came out was green and it was factory coolant
2004 996 Targa Tip
09-17-2015, 05:57 PM
#34
Beginner
[QUOTE=JayG;466485]That's not completely correct. There has also been green factory coolant. Porsche has also used yellow. The current color is pink
I just changed my WP and coolant and what came out was green and it was factory coolant[/QUOTE
And my 2003 was pink. No idea if it was factory though as I was not the original owner. So, do you know how to determine if it is coolant intermix?
2003 S manual
09-17-2015, 06:04 PM
#35
Porsche has made their coolant in Green, yellow and pink. All of them are factory and OK for the car and even to mix.
So you could end up with orange or other colors depending on what was mixed
In my case, I have service records for the car and the coolant had never been changed. Green is what they put in in Stuttgart, at least in my 04
2004 996 Targa Tip
09-18-2015, 02:28 AM
#36
Beginner
Vanya, sorry for the back and forth on coolant, it does not help you get your car running. The fact is if you mix the coolant commonly available with US cars and the coolant that is specified for your Boxster, the result is the two coolants can react and form a gel. If this has happened to your car the gel has to be cleaned out of the cooling system. I don't know the procedure for doing that. I was hoping a forum member with that knowledge would respond. Keep this in mind if your water pump checks out good.
2003 S manual
07-14-2016, 01:26 PM
#37
overheating
Before doing engine cooling maintainance my 2000 s it ran a little over 180*
The car has 61k so thought it time for water pump, thermostate, and coolant renew.
I also cleaned the radiators.. Also put gutter screens over the opening holes,,,the holes are about 1/2"in the screens.
After my hard work, my car runs halfway between 180* tick and the one above that whatever that is 220*??????
I followed the directions from 101 projects.
Did I not get all the air out???????? How do I proceed???
Thank you this is a great resource
Pat
07-14-2016, 01:41 PM
#38
overheating
Several things a failed to mention,
New rad cap,
Also battery died and lost all my gauges.
Removed ground after bleeding system. Restored my gauges
Only put 4 1/2 gallons of coolant in.
maybe a valve didn't open and now has air trapped??
Any ideas on how to proceed are welcomed.
Thanks again
Pat
07-14-2016, 03:51 PM
#39
Your car is not running hot, it is running hotter than what most consider normal temp. To say that every Boxster should be running with the needle on 8 or 0 is not accurate. I've owned my '99 for six years and it consistently runs at the right side of the 0 when warmed up. Depending on ambient temp or how hard I'm driving it or a grade it will go to where yours is in the picture and I've had no failures due to temperature.
There is an easier way to test your front fans, let the car warm up and pull it into a dirt field, if you see dust coming up from both front sides they're working and believe me you'll know. Also you should be able to hear your engine fan running when the car warms up and it is located on the passenger side and sounds like a vacuum cleaner when running.
It is a good idea to clean your radiators and condensers as they do accumulate debris and if you do decide to change out the water pump put a new thermostat in as well.
You'll soon find out that the internet is full of owners who recommend to blindly start replacing parts only to find out later that the cause of their problem was something else and they've spent a lot of wasted money.
Find a good independent mechanic that can use Porsche equipment to diagnose problems and see what they have to say. Most will diagnose without charging you then you can decide if you want to tackle repairs and or maintenance yourself or pay them to do it.
07-15-2016, 09:15 PM
#40
Does my Boxster have an oil pressure gauge?
Oops. wrong thread. Sorry.
Reason: wrong thread.
