Thread: overheating
Old 09-11-2015, 06:48 PM   #10
JayG
On the slippery slope
JayG's Avatar
Originally Posted by Jamesp View Post
I just have to say the car is certainly running hot. If it is due to a failing impeller, meaning vanes are flaking off and it can pump less cooling fluid, driving the car further may cause additional damage. An OBD2 reader, or even a Durametric will only show what the gauge does, the car is running hot. I drive mine in 90-100 degree heat, and I'm not gentle. With clean radiators my car stays in the 185 degree range regardless of outside temp or load on the engine.
James does have a point about possible broken impeller.
I just had a WP failure, but it was a leaking shaft seal, the impeller was whole
It is a reasonable easy DIY to change the WP
2004 996 Targa Tip
Instructor - San Diego region
