Not normal. Don't drive it like that. First thing, remove front fascia and clean the gap between the AC condensers and the radiators. If that is packed with trash, which is common, run it and see if it is fixed, if not, you've likely a damaged water pump impeller, so check that next. Temp needle should be passing through the low side of the 8.
2003 S manual
