Thread: overheating
Old 09-17-2015, 06:24 PM   #26
Jamesp
Beginner
Jamesp's Avatar
Stop driving the car
That is certainly good advice. Both the water pump and the rear overflow hose dump water by the right rear tire. So, the pump could be leaking, or the car is getting really hot and the pressure is causing the coolant to dump out of the overflow. When I rebuilt my engine I had coolant blow out the rear overflow after initially filling it with coolant. That was likely due to air in the system. Has the coolant been changed or drained and replaced recently? Is the coolant green or pink?
2003 S manual
