Old 05-07-2015, 09:49 AM   #1
1998 Boxster Owner
Lightbulb Better Gas Mileage using Shell Gas vs Chevron
Not sure if the specifics of Shell vs Chevron have been addressed in these forums but I was using Chevron in my 98 Boxster only because of convenience, Chevron is on my route home from work.
I filled my car up with Shell about a month ago over the weekend and didn't have to fill up for about 2 1/2 weeks of driving back and fourth to work. My commute is only 8 -10 miles one way, depending on traffic I take back roads when the freeway traffic is heavy.
I filled up with Chevron on the next go around and my gas only lasted about 8 business days before I needed to fill up again. I kept the my Boxster parked on weekends to test my theory - now I need to zero out my travel mileage next time I fill up to confirm.
Anyways - just wanted to share my experience as I am still a fairly new Boxster owner.
Benitom is offline   Reply With Quote
Old 05-07-2015, 10:11 AM   #2
steved0x's Avatar
I have had that same experience with Murphy gas at WalMart vs Shell gas. Shell is all I get now unless I can't help it. When I can't, I get Chevron (oddly ). I never get no-name gas anymore like "Racetrack", "Kangaroo".
Old 05-07-2015, 10:51 AM   #3
Porsche9's Avatar
The base gasoline pretty much comes from the same refinery. Each brand then adds in the own additives. Stick with "Top Tier" gas and you should do fine. Also, stick with stations that have a high turn over. Gas gets old/bad, so going to a low turnover station increases the risk.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 05-07-2015, 11:35 AM   #4
X GI
SJEFFB986's Avatar
I use Wawa 92 unleaded. Plenty of turnover at any Wawa gas/convenience store...and I think they put a little bit of coffee in the gas for the extra boost. ha ha..
Daily Drivers:
2013 Passat SE
2001 RX300
1999 Boxster
SJEFFB986 is offline   Reply With Quote
Old 05-07-2015, 11:54 AM   #5
I understand that as various refiners push their product down the actual pipeline, it flows like cars on a frieght train, with no air gap. So the beginning and end of a large slug, where they might be a cross between two companies products, is sold on the open market at the gas terminal via the spot market. The independent stations are the primary customers of the spot market. So they may end up with buying a cross mix of two major refiners version of regular. That unknown is one reason why I stay away from the independant stations.
Old 05-07-2015, 12:03 PM   #6
Porsche9's Avatar
Originally Posted by BFeller View Post
I understand that as various refiners push their product down the actual pipeline, it flows like cars on a freight train, with no air gap. So the beginning and end of a large slug, where they might be a cross between two companies products, is sold on the open market at the gas terminal via the spot market. The independent stations are the primary customers of the spot market. So they may end up with buying a cross mix of two major refiners version of regular. That unknown is one reason why I stay away from the independent stations.
I would think this situation happening depends on where you live. In Arizona we use to get all of our gasoline from one refinery in California but a few year back they built a pipeline from Texas. Not sure if it gets mixed but it certainly helped lower prices.
Ethanol gets mixed into gas so there could be some variation on the percentage mix in the final product that could impact mileage as ethanol negatively affects mileage as it's less energy dense then gasoline.
Again, stick to Top Tier gasoline and you should be fine.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 05-07-2015, 12:08 PM   #7
Luv2Box's Avatar
When I fill the tank with Chevron my OBC reads 340 miles for the tank and when I fill with Shell it reads 299 miles for the tank. The reading is taken right after the fill sitting still. Any thoughts on what causes this?
Luv2Box is offline   Reply With Quote
Old 05-07-2015, 12:09 PM   #8
I always use Shell. There is no ethanol in the premium grade.
'99 black 986
Old 05-07-2015, 12:45 PM   #9
Did you check to make sure conditions are the same? Your current average mpg when filling the tank.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 05-07-2015, 01:42 PM   #10
Joe B's Avatar
Maybe in Canada, but there is ethanol in Shell premium in the US. I use only Sinclair locally, since it's the only non-ethanol gas in town (all grades).
Old 05-07-2015, 02:26 PM   #11
Luv2Box's Avatar
Yes conditions appear to be the same the fuel gauge needle is right on the full mark. For some reason the OBC is indicating I will get more miles on a tank of Chevron than a tank of Shell.
Old 05-07-2015, 03:33 PM   #12
I get terrible gas mileage no matter what brand I put in...
that's what makes these cars so much damn FUN
"Cool Prius!"
- Nobody
Old 05-07-2015, 03:34 PM   #13
BYprodriver's Avatar
While I worked at both Shelby & Saleen during the EPA emissions certification process for new manufactured vehicles, 2 different emissions certification engineers were adamant about using nothing but Chevron Supreme in test cars. That's all I use & it's usually the most expensive option. I just paid $4.12 per gal at my local station.
Old 05-07-2015, 06:07 PM   #14
MPG??
I'm more concerned about GPM( grins per mile). Nothing beats my Boxster S!!
Phil C is offline   Reply With Quote
Old 05-07-2015, 08:48 PM   #15
kls
That might not be the most scientific test of MPG. Even if you were taking the exact mileage, the wind, how fast you drove and how often you hit red lights would effect it, but counting how many days a tank lasts is pretty unreliable.
kls is offline   Reply With Quote
Old 05-07-2015, 09:03 PM   #16
was going to say is one station ethanol and one 100%?
antny is offline   Reply With Quote
Old 05-07-2015, 09:14 PM   #17
I have been trying to manage the weight of my Boxster Spec race car through the amount of fuel on board. Spec racing has a minimum weight of 2650 lbs with driver at the end of the race. Usually, the top 3 finishers are weighed immediately following a race.
Me and my car weighs about 2650lbs with no fuel, so I am trying to minimize the amount of fuel on board with the goal of having only 1 gallon left at the end of a race. Any additional fuel beyond the optimum amount is simply excess weight that is slowing me down.
This should be simple, right?
Thus far, this has been a massive failure due to the inaccuracies of the gas gauge. Not only is the gauge wrong, it is non-linear and not-repeatable, i.e., when the gas gauge shows a half tank, the number of gallons actually in the tank will vary.
Thus, based on this experience, anything less than an almost absurd dedication to detail and exact measurements of fuel used, distance driven, and engine load will be useless in determining repeatable MPG numbers to the accuracy needed to compare one brand of gas to another.
Old 05-07-2015, 09:53 PM   #18
Retroman1969's Avatar
Originally Posted by Phil C View Post
MPG??
I'm pretty much in this camp.
I seem to average around 24 mpg (pretty decent) no matter what the brand or conditions. I don't anylize it any deeper than that because I'm too busy enjoying the car!
Old 05-07-2015, 10:07 PM   #19
Porsche9's Avatar
$4.12 per gallon! What's in that gas that it's $4.12 a gallon? The Chevron by my house is $2.83 for super.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 05-08-2015, 05:44 AM   #20
Yeah, I've done that.
leftfield6's Avatar
To the original poster's question, though, one tankful is not near enough of a sample size to determine any changes in fuel economy. To accurately gauge fuel economy, you need a large sample size.
For the argument about one brand of gas is better than another, I give you this.
1999 Boxster, Tiptronic, Hard Top, Arctic Silver with Boxster Red Interior
leftfield6 is offline   Reply With Quote
