Old 04-18-2015, 02:28 PM   #1
Beginner
Jamesp's Avatar
Stipped heads on Front Rotor Countersunk Philips Screw
Anyone have a slick removal technique? I can drill and chisel as well as the next guy, but if someone has a slick trick I'm all ears.
2003 S manual
Old 04-18-2015, 02:46 PM   #2
First some Kroil several times over 24 hours.PB Blaster or ATF second best choice.
Mig weld a bolt on it ?But you need to be very good at precision welding.Hold the bolt in a fixture in the correct position about 2mm away from the old phillips head.Do not forget to disconnect the battery!!
Left hand thread easy-out ?
Old 04-18-2015, 03:12 PM   #3
Pdwight's Avatar
You might be able to take a good hard punch and peck it out after the Kroil or PB Blaster.
Old 04-18-2015, 03:30 PM   #4
Heat up with torch, when hot spray with pb blaster, leave overnight. Impact screwdriver. Worker for my rotor screws.
KenDFW is offline   Reply With Quote
Old 04-18-2015, 05:28 PM   #5
steved0x's Avatar
+1 on impact screwdriver, that's how I got mine out. Replaced them with stainless ones from Lowe's and I put a little antisieze on the fir next time. I got the tool from O'Reilly auto parts for around $8-10.
Old 04-18-2015, 05:50 PM   #6
Registered Boxster abuser
healthservices's Avatar
+2 on impact driver
Old 04-18-2015, 06:03 PM   #7
+3 on impact driver. Worked great for me.
Old 04-18-2015, 08:11 PM   #8
Take a cold chisel and whack a slot all the way up to the outer circumference of the bolt. Then, put screwdriver in the slot, angle it and hit it with a hammer so it applies force in a counterclocwise direction.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-19-2015, 03:35 AM   #9
Bruce Wayne's Avatar
+4 on the impact driver.
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 04-19-2015, 11:10 PM   #10
rdass623's Avatar
use a dremel and cut a deep slot into the screw head and use a large regular screwdriver. also after cutting the slot into the head be sure to tap the screwdriver deeply into the new cut to ensure a good bite for the blade.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 04-20-2015, 05:59 PM   #11
Beginner
Jamesp's Avatar
+5 On the impact driver. I've never used one before and wow! The screws came out with a few taps of the hammer, even the stripped ones! Why didn't I know about this tool already? Man that saves a lot of time and work! Thanks folks!
2003 S manual
Old 04-20-2015, 06:53 PM   #12
Pdwight's Avatar
It has been around for decades , I used ones to remove the windscreen screws on my 1978 FJ 40 in the late 70's
