First some Kroil several times over 24 hours.PB Blaster or ATF second best choice.
Mig weld a bolt on it ?But you need to be very good at precision welding.Hold the bolt in a fixture in the correct position about 2mm away from the old phillips head.Do not forget to disconnect the battery!!
Left hand thread easy-out ?
