Old 04-01-2015, 01:38 PM   #1
steved0x's Avatar
I'm interested in picking up one of your detent mods. Every once in a while when the car is cold it will pop out. Changed the trans oil not too long ago and everything appeared okay. Is it a fairly easy mod to install? Let me know. Thanks.
I am interested in the detent mod as well.
Old 04-01-2015, 01:48 PM   #2
The reports in the Porsche Forums on Swepco vs the OEM 6-speed trans oil are rather confusing. There are reports good/bad about both oils. The obvious variable seldom mentioned is the condition of the internals of the gearbox. The well known weakness of bearings(the seals fail -just like the IMSB !) and the 2nd gear synchro +dog teeth /pop-out seem a more likely cause of variable results from the two oils?
Part of the reason for the confusion is that there are very few diy gearbox inspection guides. This is a pity because if every time the gearbox was out for clutch/RMS/IMSB work, the gearbox was inspected internally ,it may help? Meanwhile the 'sticky finger' test I mentioned previously is an easy predicter of future bearing problems and perhaps synchro +dog teeth also?
Another issue is that the trans oil is seldom changed as frequently as the gearbox re-builders recommend. Yes the oil change+ the detent mod is expensive -but compared to a gearbox rebuild ,it is a bargain! Justa sk Erik how much a rebuild costs and you'll love the alternative/preventative.
Old 04-01-2015, 01:51 PM   #3
Before using a 'cheater bar' - may I suggest a gentler alternative ? Try PB Blaster or Kroil several times over a few days.It worked for me.
And put some anti-sieze on the threads when you replace the filler + drain ?
Old 04-01-2015, 07:25 PM   #4
Pdwight's Avatar
Just did this
my 2001S had the original oil in it and it didn't look too bad. I drained out 2.8 L and put 3 back in. Pelican says it should hold 3 quarts...so if you buy 3 1 liter bottles put it all in.
