Old 02-08-2015, 06:21 PM   #1
I am my own mechanic....
Timco's Avatar
Sump pan reinstall torque?
Searched and read the first 5 threads or so. Figured I'd ask.
How long do I let the sealant set before reinstalling? Final torque? Pattern?
Thank you.
ETA...clean. Not a speck of plastic or metal. Magnetic plug had a very slight film on it. Sweeeeet.
'08 VW Touareg T-3 wife's car
Old 02-08-2015, 07:54 PM   #2
As a general rule M6 bolts into the M96 are 10Nm. But that assumes you chased the threaded hole and cleaned swarf/oil/dirt out. I usually use a little less but use blue loctite.On the sump plate I used green because of removing it for inspection.
The sealant -whatever you do it is a nuisance because at some stage you'll need to remove/clean the sealant. I used DreiBond(3bond) and followed the directions. Use only the absolute minimum size bead -3mm max. I try to place it toward the outer edge to prevent ooze getting into the sump. I would rather have a little weepage of oil that lumps of sealer floating in the oil.
I am tempted to try Hylomar because it may be easier to remove.
The sealants are anerobic so slap the parts together asap and leave them for a day or more to set.
Just pretend the bolts are cylinder head bolts and use that criss-cross pattern and tighten in many progressive stages. I use an old aircraft mechanics 1/4 dial-type torque wrench.Full deflection is 9+Nm. so it is easy to see.
On my recent deep sump project I replaced all the bolts with custom length s/s studs+red loctite - so much easier and no chance of stripping threads. From a geekish engineering point of view ,the studs are a good way of dealing with this issue in other parts of the engine also.
Old 02-08-2015, 08:19 PM   #3
Timco's Avatar
Thanks. I'll convert that to ft-lbs. my torque wrench only has that scale.
Old 02-08-2015, 10:03 PM   #4
rdass623's Avatar
i used my 12 volt dewalt impact driver to reinstall mine. just remember to use a super thin "skin" of sealant. if you use a bead, it will squeeze out and the silicone on the inside may come loose and clog your pick up tube screen.
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 02-09-2015, 03:03 AM   #5
Dlirium's Avatar
Timco - here is a pelican article that may be useful...
Pelican Porsche Tech Article - Installing a Deep Sump Kit - Porsche 911 - Porsche 996 Carrera (1998-2005), Porsche 997 Carrera (2005-2008)
Old 02-09-2015, 03:44 AM   #6
Beginner
Jamesp's Avatar
7.5 foot pounds, and personally I'd skip the locking compound if you plan to check this often. I only use locking compound on bolts that stay bolted.
2003 S manual
Old 02-09-2015, 06:02 AM   #7
steved0x's Avatar
Similar story for me, 10 NM on the bolts, and I did use blue Loctite. I cannot remember if I used an alternating pattern or not, but I don't believe one was specified. I personally went around a couple of times and tightened them up little by little, and then once the torque wrench clicked I went around and did them all again.
What really helped me was I went to Lowe's and got 3 longer bolts that matched the sump bolts and got the heads cut off using the machine that cuts links of chain. Then I threaded these (now studs) into the the sump and used them as a guide to make sure that I was sliding the cover on correctly. This helped me make sure that I didn't smear the sealant all over...
Old 02-09-2015, 08:57 AM   #8
Dlirium's Avatar
Wow, I'm about to do mine as well, and that is SOLID advice! Great idea, thanks!!
Old 02-09-2015, 09:02 AM   #9
Dlirium's Avatar
Or 85 inch-lbs.
Old 02-09-2015, 09:14 AM   #10
" I only use locking compound on bolts that stay bolted. "
GREEN (WICKING ) Loctite is perfect for sump plate bolts.Alternative is Purple.
Why do you think Porsche used MEC bolts all over the M96?
Red Loctite or blue would be a different story.
If, by mistake/intent you use blue, and want to remove the bolts easily - 'crack' them when the engine is hot.
Without a threadlocker, heat cycling/vibration may loosen the sump bolts - unless you over-torque.
Old 02-09-2015, 09:20 AM   #11
BYprodriver's Avatar
That is true with the exceptions having the 10.9 grade marking on the head. They are torqued to 10 ft/lbs. Cam-cover, case perimeter, camshaft timing gear bolts are 10.9 & torqued to 10 ft/lbs.
