Old 01-09-2006, 08:02 PM   #1
rbennett's Avatar
Proper engine warm-up
I'm curious to see how other Boxster owners start their cars up when the engine is stone cold.
My routine consists of
Start and let idle for 1 min (not applying any gas pedal)
Take off and never let the engine go above 2500 RPM until 180deg is reached
(I have a tip, so it requires constant upshifting)
After 180deg is reached, give it hell
On shut down it is:
Let engine reach normal temps first.
Prior to shutting off engine, let it idle for 1 min .
(this lets a slobbery coat of oil coat all the parts at low rpm)
With all the well known int shaft issues, maybe RMS and cylinder sleves I just wonder if this is a result of improper warmup???
I grew up on a ranch and my grandfather would kick butt if I treated any ranch equipment other than the above.
Regards
"The Rodney Dangerfield of Porsche mods"
2000 2.7 Lapis Blue Boxster, Sports Pkg, Lit, Tip, Exhaust, De amber'fied
1983 911 SC Coupe 3.0 Gaurds Red (restoration, in pieces)
199? 993 Coupe Gaurds Red (lurking for....)
rbennett is offline   Reply With Quote
