Old 01-09-2006, 08:02 PM   #1
rbennett's Avatar
Proper engine warm-up
I'm curious to see how other Boxster owners start their cars up when the engine is stone cold.
My routine consists of
Start and let idle for 1 min (not applying any gas pedal)
Take off and never let the engine go above 2500 RPM until 180deg is reached
(I have a tip, so it requires constant upshifting)
After 180deg is reached, give it hell
On shut down it is:
Let engine reach normal temps first.
Prior to shutting off engine, let it idle for 1 min .
(this lets a slobbery coat of oil coat all the parts at low rpm)
With all the well known int shaft issues, maybe RMS and cylinder sleves I just wonder if this is a result of improper warmup???
I grew up on a ranch and my grandfather would kick butt if I treated any ranch equipment other than the above.
Regards
"The Rodney Dangerfield of Porsche mods"
2000 2.7 Lapis Blue Boxster, Sports Pkg, Lit, Tip, Exhaust, De amber'fied
1983 911 SC Coupe 3.0 Gaurds Red (restoration, in pieces)
199? 993 Coupe Gaurds Red (lurking for....)
rbennett is offline   Reply With Quote
Old 01-09-2006, 08:27 PM   #2
I have a similar ritual but not quite. I let the car sit until the idle settles to 750 rpm(though Porsche states to just go). I don't exceed 3,500 rpm until up to temp(porsche says you can take it to 4,200 when cold). I just shut it down and let it sit once done.
Old 01-09-2006, 09:43 PM   #3
Well...... I guess your approach wouldn't hurt, but not sure it is neceesary. With today's engine and oil, let the engine idle for one minute is plenty. As for shutting down, I don't have any procedure other putting it in the first gear.
underDAWG is offline   Reply With Quote
Old 01-09-2006, 10:12 PM   #4
I am in San Jose and the weather is like Fresno.
I start it up and since I live about 3 minutes from the freeway I am up to a "tad" beyond the speed limit and in the rev limiter. Then I shut it off when I arrive.
Been doing this for almost 7 years. Car has almost 60k miles. No engine or RMS issues.
Guess I will not be going to Porsche heaven.
Old 01-09-2006, 10:52 PM   #5
TriGem2k's Avatar
Send a message via AIM to TriGem2k
My car idles a good 10minutes every morning before i take off.....Never really done anything special on shut down except turn it off...
TriGem2k is offline   Reply With Quote
Old 01-10-2006, 12:58 AM   #6
I could have sworn the manual for my new 987 says to start the car and drive immediately without letting it sit and idle.
faterikcartman is offline   Reply With Quote
Old 01-10-2006, 05:15 PM   #7
Brucelee's Avatar
"With all the well known int shaft issues, maybe RMS and cylinder sleves I just wonder if this is a result of improper warmup"
No, these are design issues well known by Porsche.
Rich Belloff
