11-13-2012, 06:27 AM
A/C and fan speeds
I've read a number of posts about Boxster fan speeds.
With the A/C off, it's clear the fans are off when the coolant temp is below a specific temperature (say T low) and on high speed above a different temperature (say T high). In between T low and T high, the fans run at low speed.
Here's my question. When the A/C is turned on, do the fan operate at low speed immediately even if the engine has not warmed up to T low? my fans operate at high speed when the refrigerant pressure goes above a certain pressure.
I'm asking because either the fans aren't turning on a low speed when I turn on the A/C or they are on but I can hear them above the engine noise. I don't have a tool to test the fan operations directly.
11-13-2012, 09:05 AM
1999 base
hello thom.
the fans are controlled by 4 different relays, located above the fuse box on the driver side kick panel.
you can remove the relays and "jumper" legs 30&87, to activate each fan in its relevant speed.
let me know if you need more details, i will try to post some pics.
you should be able to activate each fan separately, both in high or low speed.
if one of the functions doesn't work, it usually has to do with defected fan resistor.
with that said, when the fans are on low speed, it is very hard to hear them.
11-13-2012, 09:49 AM
Thanks Meir:
I tested the relays by putting my finger on each relay and pushing the snowflake button to activate the A/C. When I do this, the relays click, which I could hear and feel. I still can not hear either fan on low speed.
So my next move is to jump the pins. Here's my follow up question. When I pull the each relay, how do I know which pin is 30 and which is 87?
11-13-2012, 10:24 AM
2001 Arctic Silver 2.7
Originally Posted by thom4782
Thanks Meir:
thom4782:
Most relay have them labeled on the bottom by the pins.
Example
RMS, IMS, 87.5K
11-13-2012, 11:23 AM
1999 base
Following Tony's excellent pic,And just to clear.
leg 30 is the center vertical, and 87 is top horizontal.
(purple and red in Tony's pic).
11-13-2012, 11:59 AM
Thanks everyone for the advice. It was very helpful. Unfortunately, it looks like bad new for me. When I jump the fans to test low speed, neither one comes on. When I jump the fans to test high speed, both work. It looks like I'll need two ballast resistors. I'll have the independent shop test in the morning using its computer just to make sure. Again, thanks
11-13-2012, 12:21 PM
Can you clarify; turning the AC on switches the relays but the fans do not run, i.e. if you walk to the front of the car they are not running?
I ask because I have always assumed that the resistors fail by presenting an open circuit and you can verify their integrity by measuring their resistance < 1ohm between pins 30 of the low and high speed relay sockets. I have yet to let my car run long enough to have the high speed fans kick on. I should probably do the jumper trick to at least hear what they sound like.
11-13-2012, 01:03 PM
I'll be glad to clarify.
I've preformed several tests. Last night, I turned on the A/C with the engine cold. I could not hear either fan operating at low speed. I waited until the refrigerant pressure triggered high speed fan operation, both fans operated. So I know at this point, both fans work and the fuses are OK.
This morning with the engine cold, I pulled out both low speed relays and jumped them to see if the fans cam on at low speed. They did not. I repeated the test by turning the ignition on. No operation. I started the car with the AC off. Still no low speed operation. Finally, I turned on the A/C. Still no low speed fan operation. When I removed the high speed relays and jumped them, the fans operated at high speed
My understanding is that with then engine cold and the A/C on, jumping the low speed relays will start the fans. In my case, this didn't happen.
If I had a multimeter, I would try measuring the resistance between the 30 pins on the high and low speed relays. But alas, I don't.
BTW: My understanding is that both fans run a low speed when the A/C is on. If I'm wrong, I'd love to hear about it bcause it could be that the fans only operate a low speed when the coolant gets hot enough. If that's the case, then my test wouldn't not have worked because the engine wasn't up to operating tempereature for the thermostat to turn the fans on.
11-14-2012, 10:36 AM
Does anyone know if it is possible to test the resistance of the ballast resistors using a multimeter in the relay panel. If so, which pins would I use - 30 and 87 in the stage 1 relay sockets?
I'm looking for a way to confirm the resistors are bad before I start opening up the front of the car to replace them.
11-14-2012, 12:33 PM
Down in this thread you can find the instructions. Basically you want to measure between pin 87 of the low speed relay socket and pin 87 of the corresponding high speed relay. The ballast resistor is connected across these pins.
The claim is the resistor should be 0.55 ohm. I have a standard dmm which cannot measure this accurately, my leads have nearly half-ohm by themselves. I think you simply want to make sure that you measure 1 ohm or less meaning the resistors are intact. They should only fail by presenting an open circuit, not a short, afaik.
Radiator fan not turning on when AC is off - 986 Series (Boxster, Boxster S) - RennTech.org Forums
11-14-2012, 03:12 PM
Thanks everyone for the advice especially as it related to jumping the stage 1 relay to see if I could make the fans run at low speed and the pins identifiaction needed to measure the resistance of the ballast resistors.
The car failed both tests. So it's time to unbutton the front and replace the two resistors. And, while I'm doing that, I get to clean the debris between the condenser and the radiator.
11-14-2012, 04:17 PM
1999 base
You do not need to remove the bumper to get to the resistors, but it's a good idea to do so, and clean the radiators. Did that last weekend. Very easy.
11-21-2012, 02:00 PM
Can anyone suggest a good DIY reference (hopefully with some pictures) for changing the ballast resistors? I'm looking for one that gets at the resistors by removing the fender liner. Thanks
11-21-2012, 02:22 PM
1999 base
hello thom.
if you jack up the car and look at the corners of the bumper from underneath, you should be able to see the resistors (one on each side).
i'm not sure about the location of the connector, but i can have a look and post a picture later.
11-21-2012, 03:13 PM
Meir:
I found a really simple DIY at http://www.renntech.org/forums/tutorials/article/40-removing-and-installing-ballast-resistor-for-the-radiator-fan-motor/. Essentially, it says to:
- From underneath, unclip the old resistor
- Cut the wires about 1.5" from the old resistor
- Do the same with the new resistor
- Slide heat shrink over the old wire and the splice the new resistor to the old harness using crimp connectors
- slide heat shrink over the new splice and shrink using a heat gun
- clip the new resistor into the bracket
This was for a 996. I'll give it a look and see if this as easy as it sounds. If not, I'll either have to pull the liner or fender off and replace the resistor with its harness.
Thom
11-21-2012, 06:31 PM
1999 base
Meir:
Thom
that makes sense.
here are some photos i took earlier this evening.
if you look at the lower corner of the bumper, you will see a "hole" between the bumper and the plastic cover.
here you can see the resistor.
the wires go up
and ens behind a plastic cover, attached to the back of the fan.
i spent couple of minutes trying to remove this cover, with no success.
it looks like its held in place by two clips that are very hard to reach.
the way i see it you have two options.
1. cut the wires and connect the new resistor as described in the DIY you found.
if you go that rout, i suggest soldering the wires, and using a water proof heat shrink. this type of heat shrink has glue in it, and i think you can get it at radio shack. as you can see, the resistor is located in a place that can easily get wet.
you don't want to have corrosion issues after the winter.
2. remove the bumper, air scoops and radiators. remove the plastic cover at the back of the fan, and plug in the new resistor.
if you have the time, go for the second option. it is not that complicated, and you also get to clean all the dirt accumulated on the radiators.
you will be surprised do see how much crap will come out of there.
good luck, and happy thanksgiving.
11-24-2012, 03:38 PM
I'm going to try Meir's suggestion in the next day or two. Before I do, I have two questions.
1. The resistor has two different wire connections. One is a plug and it's clear how to attach it. The other is two bare wires. See picture
I presume these bare wires attach to the fan motor. Does anyone know how they actually attach to the fan motor?
2. If I try to do this job by taking off the front bumper cover, can I reach behind the radiators and make the repair or do I have to also loosen the fender liner. The shop manual says to fix by removing the liner, but I heard the job can be done by removing the bumper cover.
11-24-2012, 08:57 PM
1999 base
Hi Thom.
The two wires should be soldered to the fan, under the plastic cover (showed in my previous post).
I'm not sure about getting to the fan when the bumper is removed ( didn't pay attantion at that time), but removing the liner is not that big of a deal.
To remove the bumper you will have to take the two front clips of the liner any way, to get to one of the screws holding the bumper.
Remove the bumper, and move from there.
Don't forget to remove the AC radiators, and clean Between them and the cooling rediators.
Good luck.
I sent you a PM with my phone number.
Don't hesitate to call if you need any help.
10-31-2015, 02:10 PM
I am having a similar problem with my Boxster, and I suspect the problem is the ballast resistor. All 4 relays are working. I pulled them all, and shorted from terminal 30 to 87 on all 4 relays. Both run fine in high speed, but neither will run at all in low speed. I checked the resistance between terminal 87 of both the high speed and low speed relays, and it was infinity. So, have i diagnosed it properly before I order the resistors?
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
