Old 11-13-2012, 09:05 AM   #2
Meir
1999 base
Meir's Avatar
hello thom.
the fans are controlled by 4 different relays, located above the fuse box on the driver side kick panel.
you can remove the relays and "jumper" legs 30&87, to activate each fan in its relevant speed.
let me know if you need more details, i will try to post some pics.
you should be able to activate each fan separately, both in high or low speed.
if one of the functions doesn't work, it usually has to do with defected fan resistor.
with that said, when the fans are on low speed, it is very hard to hear them.
