07-26-2012, 07:34 AM
#21
Mobile Porsche Surgeon
Originally Posted by truegearhead
Nice work! Keep everything very organized especially the transmission bolts. There is a lot of wrenching and even more reassembly. An organized disassembly will payoff big time. If your like me and just ripped the thing apart you might be stuck buying transmission bolts at $15 bucks a piece!
Part boxses are Golden.
Mike's Specialty Porsche Service
Mobile Mechanic Specializing in Porsche and Select Automobiles
http://www.mikesspecialtyautomotiveservice.com/index.html
Early 1996 / 97 Boxster, 130 k, De snorkeled, IMS, Top Speed Headers.
07-26-2012, 07:41 AM
#22
Originally Posted by kashmir
Also the header flange is busted, damn it looks like new SS headers.
Just a quick FYI. Two of my header bolts broke off and ended up being an absolute nightmare and a common one. I bought every single bolt releaser there is and ended up towing the car to a machine shop. The headers are sweat though. I went with ebay units and they worked great. Lined up perfectly
2003 911 C2
NASA HPDE Instructor
07-26-2012, 07:56 AM
#23
Have had a lot of experience with undoing stuck and busted bolts. I worked my way through college as car and motorcycle restorer for a private collector, my last go-round was pulling cracked full Ti bolts for a customer. When I was done you could not tell that I had done any work on the part.
07-26-2012, 08:48 AM
#24
Missing bolt part (999-072-009-09), can't wait to see the hack-up work that has been done in the past.
08-08-2012, 09:46 AM
#25
Pulling transmission
08-08-2012, 10:04 AM
#26
Photo; Pelican Porsche.
A; 12 mm, 12 Point Triple Square Bit. available from Pelican.
D; access though top of car, my was a 16 mm head.
H; 15 mm nut, access from behind transmission.
08-08-2012, 10:10 AM
#27
Need to pull intake for transmission to clear, replace with Pedro's mod on his website.
08-08-2012, 10:11 AM
#28
Theoretical propagandist
This is an interesting fact as I was also missing the same bolt on my 98'. Wonder if this is common.
08-08-2012, 10:13 AM
#29
De-greased transmission.
08-08-2012, 10:23 AM
#30
My manufactured by Yugo shift linkage is in very bad shape, going to see if I can have new ends made.
#31
I'm inspired by what you and others on this board are capable of doing to your engines! Thanks for posting your progress and pictures.
08-08-2012, 10:29 AM
#32
08-08-2012, 11:07 AM
#33
Man, after all that hard work just looking at all the hard work...I need a couple good old cold beers. Keep em' coming...gota go and get a case or two just to cover the rest of your post.
Old Hippie Young Heart
08-09-2012, 06:54 AM
#34
Homeboy981
WoW! Great work kashmir! I was going to suggest we do some of the work together but you are WAY TOO ORGANIZED! Not bad but I work like a "cave man" compared to laying out your tools - like a surgeon! Care to operate on an 02 S, doctor?
08-09-2012, 01:08 PM
#35
Replaced the Porsche/Yugo shift ends with DIY ones.
08-14-2012, 01:27 PM
#36
Pulling clutch.
08-14-2012, 01:32 PM
#37
Lock flywheel with big zip tie.
08-14-2012, 01:37 PM
#38
Use hand impact to help loosen bolts.
Then use breaker bar to undo bolts, then remove flywheel.
08-14-2012, 01:43 PM
#39
Finally to the back of engine. Nice no oil leaks.
08-14-2012, 01:50 PM
#40
The ims bearing cover.
