03-05-2012, 04:06 PM
#1
Dropped plastic piece into oil fill hole.
While removing the ribber middle oil filler tube, i broke the tip of the tube that connects to the engine. I saw one piece fall on the engine and thought the other out as well but it was inside the tube. So, when i tried to remove the engine side it dropped into the engine. Tried a shop vac, long wire with gummy tape and no luck. Oil is currently drained and the sump plate is off. How do I go about locating it and removing it? It's a one inch by 1/2 inch triangular piece.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
03-05-2012, 06:03 PM
#2
Ex Esso kid
If I understand you clearly, you were not fishing for the piece because you could see it but fishing blind hoping for a lucky break, if that is the case maybe you can try the following. Just an idea, since the sump plate is off, try flooding the intake with a small amount of clean oil and observe, you're going to need a big catch and some luck.
03-05-2012, 07:31 PM
#3
I will give that a try. I thinking maybe get one of those drain cams and see where it's at. But, I'll give the oil thing a try.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
03-20-2012, 03:25 PM
#4
Didn't try the oil fill trick yet as the sump plate is out and the so are many other parts. Did get the tool with the camera at the end of a hose that is used for drains. Can't seem to find it. When removing the clutch I turned the engine so might have gotten stuck somewhere. Looking from the bottom I think it should have fallen or will fall into sump if it didn't get chewed up.
Should I remove the spark plugs and turn the engine (easily) until it falls?
Any ideas guys? I definitely don't want to leave it in there even tho it's plastic.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
03-21-2012, 01:43 AM
#5
Bumping for some attention!!
Can't imagine noone else has dropped anything in the engine ever!
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
03-21-2012, 04:27 PM
#6
Sweet success!!
Can see it sticking it's ugly sharp head out of the round hole. Forced air from shop vac did the trick. :dance:
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
03-21-2012, 06:22 PM
#7
Originally Posted by Bala
Sweet success
Nothing beats the huge sigh of relief when you work your way out of a pickle like that, nice job.
03-22-2012, 04:36 AM
#8
Ex Esso kid
When wrenching "there is no substitute" for patience and relentless persistence, good job. Case looks like a convict under hack has been on it with a toothbrush and polish.
03-22-2012, 06:17 AM
#9
That's why I hate plastic.....:troll:
Old Hippie Young Heart
03-22-2012, 07:00 AM
#10
That's what makes it all so fun, nice one Bala!!
03-22-2012, 07:05 AM
#11
1999 base
this is the point when you feel you love your car more then anything in the world, and forget that just yesterday you was thinking about buying a case of dynamite.
03-22-2012, 12:43 PM
#12
A determined man.
03-23-2012, 03:38 AM
#13
Guys,
you all can probably imagine my state of mind. I was so happy when i saw the plastic piece stick out of the hole. This car is a love hate relationship. Just when you think you want to part it out it crawls back under your skin again!
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
