While removing the ribber middle oil filler tube, i broke the tip of the tube that connects to the engine. I saw one piece fall on the engine and thought the other out as well but it was inside the tube. So, when i tried to remove the engine side it dropped into the engine. Tried a shop vac, long wire with gummy tape and no luck. Oil is currently drained and the sump plate is off. How do I go about locating it and removing it? It's a one inch by 1/2 inch triangular piece.
