Old 03-20-2012, 03:25 PM   #4
Bala
Didn't try the oil fill trick yet as the sump plate is out and the so are many other parts. Did get the tool with the camera at the end of a hose that is used for drains. Can't seem to find it. When removing the clutch I turned the engine so might have gotten stuck somewhere. Looking from the bottom I think it should have fallen or will fall into sump if it didn't get chewed up.
Should I remove the spark plugs and turn the engine (easily) until it falls?
Any ideas guys? I definitely don't want to leave it in there even tho it's plastic.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
