Old 01-02-2014, 09:33 PM   #21
BruceH's Avatar
Originally Posted by TerryT View Post
Hi,
I just pulled it out using those special tools (remember to place screwdrivers through the holes of the tools when you get purchase and pull on the screwdrivers, using your fingers alone will be quite painful).
I did not ground it, although it is suggested that you disconnect the battery.. I didn't do it and it worked just fine.
All you need to do is plug it in at the back, and feed the connector to the front.
Also, you will need to 'activate' AUX on your radio by pressing the TP button for a few seconds and selecting AUX to ON from the menu.
Shouldn't take more than a few minutes.
Terry
I picked up on this old thread with the plug in the back of the Becker CDR 220 that you then use the 3.5 m jack to plug into my iPod/iPhone. Easy enough and cheap but when I hit the S (Source) button to switch to AUX the choices I have are FM1, CD, and Magazine. No AUX. I figure okay let's try Magazine which was for the old CD player. What is odd is that Magazine does not hold and it reverts back to FM1 or CD depending what the unit is currently on. Am I doing something wrong? Does anyone have any insight? Thanks in advance.
Did you activate the AUX option?
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 01-02-2014, 09:35 PM   #22
To enable AUX on CDR-220;
1. Turn radio on
2. Press and hold the "TP" button for about 8 seconds until "Becker 1" is displayed.
3. Turn the Tuning Knob until AUX OFF is displayed.
4. Press either button located directly under the Arrows on the display to
change the present setting from OFF to ON.
5. Turn radio OFF.
6. Turn Radio back “ON” and press “S” button to select AUX Mode.
Old 01-02-2014, 09:58 PM   #23
Porsche9's Avatar
1. Turn radio on
5. Turn radio OFF.
Thanks for getting back so fast. I really appreciate it! Still no luck on getting AUX after following your instructions. Got AUX on as you see in the photo and I still only get Magazine.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 01-03-2014, 08:11 AM   #24
ppbon's Avatar
If you have the CD changer installed and connected to the radio it won't show AUX, but MAGAZINE or CD - TRACK __
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 01-03-2014, 09:04 AM   #25
Porsche9's Avatar
Happy Boxstering,
Pedro
Thanks Pedro! That did it. I actually still had the center plug for the CD Player plugged in.
BTW - I am real happy with the UDP. We talked on the phone a few weeks ago. Install was fairly straight forward and it works as described. The only downside I have noticed so far is when running the headlights you get a short interruption/pause to the stereo when you first get on the gas.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 01-03-2014, 05:16 PM   #26
jim_hoyland's Avatar
There are several sellers on eBay selling the various aux cables. I bought two....
jim_hoyland is offline   Reply With Quote
Old 04-11-2014, 06:55 PM   #27
Playing not charging!
Hi everyone.
Bought the iP-BKR2 from Discount Car Stereo (iP-BKR2 iPod Adapter for Becker and other Radios with "AUX" Menu Setting :: iPod Adapters & Interfaces)
Anyway, followed the instructions to enable the AUX mode on the 220. Now the 220 plays my iPhone in Aux mode, but does not charge.
Anyone have any ideas why it's not charging?
Thanks,
Rob T
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
Old 04-14-2014, 07:36 AM   #28
tonycarreon's Avatar
which iphone?
Old 05-02-2015, 04:49 PM   #29
CDR-220 USB Port for AUX
I just installed the USB-BKR in my auxiliary port of the CDR-220. I decided to go with the USB option so I could have more flexibility in what I plugged into the unit. I thought I would share some pictures. I was trying to go for a factory look yet still keeping the cord accessible. I ended up drilling a whole in the center console. It turns out there is already an indentation in the shelf that you can drill out and presto it's centered nicely. I am very pleased with the look and the functionality. The audio sounds great, it charges my phone and the navigation audio from my phone also plays through the speakers. Could not be happier.
:dance:
hahnster is offline   Reply With Quote
Old 05-03-2015, 10:17 AM   #30
BruceH's Avatar
That looks great! Nice job
DEPO Tail Lights
Old 05-03-2015, 11:31 AM   #31
Lightbulb! Thx.
token 00 is offline   Reply With Quote
