11-16-2011, 10:51 AM
Wd40
hey fellas,
i was reading online regarding the multiple uses of WD40. I just wanted to see what fellow boxsters thought.
i use it to rub off scuffs. its okay for the paint, correct?
i also read that by putting it on the wheels, it repels the brake dust. true? any experience with that use?
-Tuan
tuanle16@juno.com
11-16-2011, 11:02 AM
Porscheectomy
WD-40 is a mixture of lubricants and solvents. I wouldn't touch my paint with the stuff on the car or on the wheels. It's great for getting the glue residue off of labels and that's about it.
11-16-2011, 02:04 PM
I use Turtle Wax Bug and Tar Remover which works great. I am sure that there are many other similar products formulated especially for removing bugs, tar, scuffs, tree sap, etc without any worry of damaging the paint. I'd suggest using one of these products rather than WD-40.
11-16-2011, 07:15 PM
Had a guy at the local Porsche dealership tell me that WD-40's good for restoring the plastic cowling material at the bottom of the windshield (ie the area from which the wipers sprout). He said spray it on, leave it for awhile, then wipe it off with a WD-40 moistened rag. I believe he also said you could do the same on the black base of the sideview mirrors that attach them to the car.
11-16-2011, 07:50 PM
You might want to read the FAQ's on the WD-40 web site ( WD-40 Lubricates, Cleans, Protects, Penetrates & Displaces Moisture) to be better informed (it's safe on paint and great for removing bugs). They won't say what the ingredients are that make up WD-40 but I've heard it's based on fish oil.
11-16-2011, 08:12 PM
Porscheectomy
Originally Posted by Jaxonalden
http://www.wd40.com/files/pdf/msds-wd494716385.pdf
Mostly hydrocarbons ie fuels and solvents, with petrolium oil and a little other stuff. What do you think that does to wax? Or a clear coat?
11-16-2011, 08:52 PM
It won't repel brake dust (think about any oil). It will make the wheels easier to rinse.
Denver Steve
11-17-2011, 03:26 AM
hey fellas,
There are better products for removing bugs stains, tar and road debris from your vehicle other than WD-40 . For example, a good quality Bug & Tar remover (like Turtle Wax), Goo Gone and Goof Off . Even, spray silicone can accomplish the task . As far as wheels are concerned, believe it or not, Pledge is great for putting the final touch on them; especially black ones * .
* On a warm day, apply a light mist on a clean wheel and let it set-up for a few minutes .
It will leave an incredible luster .
11-17-2011, 03:52 AM
Ex Esso kid
Pledge is very good on plastic glass as well, it's not plexus but it's very good. As for lubricants, WD40 is always cheap and available, I like break free the best.
11-17-2011, 05:19 AM
Originally Posted by blue2000s
Not to be contentious here, but I'm pretty confident that most (all?) Bug & Tar Removers have solvents...otherwise they wouldn't work particularly well. I have little doubt that using them, while sometimes clearly necessary, does take off the wax. (The clear coat? Not so sure.) In that sense, WD-40 is no different. It is entirely possible there's other stuff in WD-40 that might, ultimately, be tougher on a car's finish, especially if left on for an extended period of time---I honestly don't know. As long as there is a reasonably priced product specifically made for this job, I'll go with it.
In a pinch I might use WD-40 for such a job. But (as is my practice with Bug & Tar Removers) I would quickly follow with a soapy wash mitt and a spray from the hose once the solvent had worked it's magic. Normally I'll follow that up with at least a little spray wax as the final step.
11-17-2011, 06:32 AM
Matt
When in doubt, check with your paint dude or dudette, or Porsche, for recommendations. There are plenty of great products out there so I wouldn't think of using WD-40 even if it was right in front of me. If people are using it for bug remover and other automotive (non lubricant) purposes, and it's working, it's probably fine.
11-17-2011, 07:20 AM
I definitely wouldn't use WD-40 for aftershave .
11-17-2011, 07:36 AM
Porscheectomy
Totally agree, but the OP didn't ask about bugs, he asked about scuffs. There are no abrasives in WD40, just oils and solvents so it won't remove scuffs but will more likely do some etching if anything.
11-17-2011, 02:16 PM
Autobahn Glanz
What do you mean by scuffs?... Tar? A scratch? Rubber from a drash can? Always start with warm water and a high quality car soap and apply as little pressure as possible, you don't want to have happen to the Boxster what happened to the Benz. If this doesn't work try a "high quality" cleaner wax with a warm damp applicator. Because your Boxster now has a smooth finish and a high quality wax on it tar will likely remove with just soap and water. When you have to a good tar/bug remover will work, just make sure to wash it afterwords so no residue is left and then wax it afterwords.
11-17-2011, 03:30 PM
It will not hurt the paint and is very good for getting off adhesive, certainly better than goo gone.
Rich Belloff
11-17-2011, 04:03 PM
Opposed to Subie Burble
WD-40 - Wikipedia, the free encyclopedia
Good ol' Wikipedia. :dance:
I don't know that I'd use WD-40 unless it was very sparingly, and since tuanle's talking about scuffs I figure he means small blemishes that he can work out. I don't have all sorts of knowledge about WD-40, but I imagine in small doses it shouldn't hurt the paint...it's not like you're washing the car in it.
-O/D
IMSR + RMS
Robbins glass window top
11-17-2011, 06:22 PM
Gee, according to Wikipedia the fish oil theory is an urban legend :ah: My bad.
11-17-2011, 06:50 PM
When I used this to de-badge cars, I have left it on for hours at a time. Not an issue. It works great but very old adhesive takes time and often heat, in the form of a blow dryer.
Rich Belloff
11-17-2011, 07:10 PM
Where I work we are not allowed to use this. It is flamable as an aerosol and on rags. On open flame it's as close as you can get to a flame thrower. I cringe when people have told me they used it on spark plug wires in the damp to get a car running, but I guess that works to. As it burns it smell just like kerosene
11-19-2011, 07:37 AM
the main ingredient in wd is mineral oil .
