Old 08-27-2011, 06:52 PM   #1
Goth Popper
99 Boxcutter's Avatar
Exclamation I'm in HOT water
So I'm sitting at a bar, drinking a catptain and coke, posting this waiting for my 99 boxster to cool off... (After $8 k into a seized engine, this time I'm not taking any chances.)
I don't know what it's called, a temperature LED, light? Whatever it's called, the thing is flashing red even though it's halfway between 180 and the next little mark... Anyhow, I popped the trunk and twisted the cap off the water reserveroir and it was BUBBLING HOT! I looked in there and it was kinda greenish... The bumper is also really hot. Should I be worried???
www.appleneworleans.com
99 Boxcutter is offline   Reply With Quote
Old 08-27-2011, 06:58 PM   #2
I had similar symptoms with a bad thermostat. Where in Louisiana are you?
nola911 is offline   Reply With Quote
Old 08-27-2011, 07:00 PM   #3
DenverSteve's Avatar
I would guess thermostat also. If you're seeing coolant in the reservoir, you're likely not too low - but it could be coolant level. That's what the blinking light indicates. I would have more coke than Captain if you're not wanting more hot water.
Denver Steve
Carrera, Cabriolet, 6-Speed, Black/Tan
DenverSteve is offline   Reply With Quote
Old 08-27-2011, 07:31 PM   #4
The flashing light means either low coolant or a malfunction of the intake fan. A solid light indicates an overheat condition.
A show of hands - how many of you have actually read your owner's manual?
'99 black 986
Old 08-27-2011, 07:44 PM   #5
Have you lost coolant? If you have and don't know how to refill it and bleed the system, have it flatbedded. don't risk overheating. even a brief overheating can be fatal to your motor.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 08-27-2011, 08:15 PM   #6
Yup, manual answers this one.
Sounds like you're low on coolant. Temp fix is distilled water to top up until you can get the correct coolant in there.
stateofidleness is offline   Reply With Quote
Old 08-28-2011, 01:52 AM   #7
Steve Tinker's Avatar
Whats the betting we won't hear from the OP re this problem again........
2001 MV Agusta F4.
Old 08-28-2011, 04:54 PM   #8
dollars to donuts....we won't get closure on this one...
silverboxter is offline   Reply With Quote
Old 08-30-2011, 06:53 PM   #9
Goth Popper
Unhappy
So... It's a coolant leak.
it goes strait to the ground about 2-feet in front of where you pour the water.
I lifted up the carpet in the trunk to see if it was wet and it was not.
Worst case scenario? Cost wise?
Old 08-30-2011, 07:14 PM   #10
Sounds like it 'burped' itself. Top off with coolant or distilled water (or a mix) and drive. Nothing to worry about. It means it wasn't "burped" properly by driving with the "valve" thing open on top of the coolant tank.
Old 08-30-2011, 08:07 PM   #11
Porsche "Purist"
Paul's Avatar
Never open the cap on a cooling system while the car is hot. Cars 101.
1987 924S. 2002 996TT. PST-2
Old 08-30-2011, 08:40 PM   #12
Wait hold up.. just re-read your post..
"it goes straight to the ground"
Does that mean AS YOU POUR, it's going straight to the ground from underneath the car?? or after you run it for a while, it OVERFLOWS and shows up on the ground?
With the car cold, fill the tank to the "Max" line marking. Underneath the plastic "cover" under the two caps, lift the valve clip and go drive it for a bit (put the caps on). That should remove any air from the system.
Old 08-30-2011, 10:27 PM   #13
Tank replacement is 800-900a dollars
That would be worst- case scenario.
Denver Steve
Old 08-31-2011, 03:41 AM   #14
Engine Surgeon
And the coolant that should be used in these engines isn't green.. You are asking for corrosion issues.
US Patent 8,992,089 &
US Patent 9,416,697
Old 08-31-2011, 08:05 AM   #15
Lil bastard's Avatar
T-stat or cooling fans. Could also be crap from the previous motor clogging the cooling lines, radiators, oil cooler - suspect engine installer flushed the lines thoroughly, but who knows.
From the sound of it, I'd suspect the fans. The coolant on the ground correlates to the overflow tube - designed to vent fluid if it overheats - which it would do with a fan failure.
Run AC and get out and check each side of the front bumper listening for the fans (2) running - with AC they should both be on. If not, suspect relays (there is a Hi and Lo) or the series resistor(s). Neither is a big fix.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
