T-stat or cooling fans. Could also be crap from the previous motor clogging the cooling lines, radiators, oil cooler - suspect engine installer flushed the lines thoroughly, but who knows.
From the sound of it, I'd suspect the fans. The coolant on the ground correlates to the overflow tube - designed to vent fluid if it overheats - which it would do with a fan failure.
Run AC and get out and check each side of the front bumper listening for the fans (2) running - with AC they should both be on. If not, suspect relays (there is a Hi and Lo) or the series resistor(s). Neither is a big fix.
Cheers!
